| MJHanna |
Dec 11 2014, 08:47 PM
Does this 911 make my butt look big? ![]() ![]() ![]() Group: Members Posts: 806 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
looking for ideas. Mine is cut but it not large enough to be useful. So I'm going to enlarge it and would like to see others solutions.
| pcar916 |
Dec 12 2014, 09:02 AM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
I vote for easy access in the dark on a lonely road in the mountains, or on the track between runs. What's likely to happen? Perhaps a broken or compromised fan belt. Mine gets inspected and replaced fairly often so it's never happened to me, but it did when I had the PO installed 2.7L. Not an enjoyable operation. My thinking on the size?
I choose not to give myself cramps trying to do two-handed operations through a small hole. This access hole lets me do anything I need to do, including getting the spanner onto those 3.6L pulley holes and fussing with the shims on the fan pulley. The metal is thin enough to snake out from behind the cage-crossmember, thick enough to still be a firewall, and with the Dzus fittings, is easy to remove/install. The only thing I have to do is remove the passenger seat, a 5-minute thing. When on the road, I carry a huge plastic bag to cover it if it's raining. ![]() ![]() ![]() |
MJHanna firewall cutouts for 6 Dec 11 2014, 08:47 PM
SirAndy I know it's kinda tight in there, but i really... Dec 11 2014, 08:49 PM
GeorgeRud I think that perhaps just getting a larger cut pie... Dec 11 2014, 10:12 PM
Krieger I made a cardboard template to cover the opening I... Dec 11 2014, 10:26 PM
Krieger From the F-914 build in my signature. Dec 11 2014, 10:31 PM
mepstein i have a large piece of firewall. pm me if interes... Dec 12 2014, 06:12 AM
RobW I installed a zipper and sprayed it with rust. :l... Dec 12 2014, 06:40 AM
t collins After cutting the opening, I spot welded an 1/8... Dec 12 2014, 07:10 AM
Cairo94507 Scotty and I were just discussing this for my Six.... Dec 12 2014, 08:08 AM
Scotty and I were just discussing this for my Six... Dec 12 2014, 08:37 AM
Racer Chris No hole. Dec 12 2014, 08:13 AM
naro914 Not easy to see, but we just did a very clean/stra... Dec 12 2014, 08:15 AM
Mark Henry For those that don't put a hatch in how do you... Dec 12 2014, 09:16 AM
SirAndy And Andy how did you get the alt out? Do you have ... Dec 12 2014, 12:20 PM
fixer34 My one and only experience with replacing a fan be... Dec 12 2014, 09:50 AM
SLITS
My one and only experience with replacing a fan b... Dec 12 2014, 10:30 AM
pcar916
I would think it would more hassle removing the s... Dec 12 2014, 10:33 AM
pcar916 On my 2.7, also MSD, I timed on the flywheel with ... Dec 12 2014, 10:22 AM
brant I use mine all of the time...
in fact I used it ag... Dec 12 2014, 10:47 AM
Mark Henry I just pulled my seats and pad, I didn't think... Dec 12 2014, 10:52 AM
patssle Don't need a hole to replace the belt. Here... Dec 12 2014, 12:27 PM
Mark Henry
Don't need a hole to replace the belt. Here... Dec 12 2014, 02:06 PM
patssle
Don't need a hole to replace the belt. Here... Dec 12 2014, 04:05 PM
Elliot Cannon If you have a large access hole in a fire wall, sh... Dec 12 2014, 02:16 PM
pcar916
If you have a large access hole in a fire wall, s... Dec 12 2014, 03:36 PM
ClayPerrine I am going to say this again:
[color=#000000][siz... Dec 12 2014, 03:15 PM
Cairo94507 No firewall access hole in my Six. Decided. Dec 12 2014, 03:59 PM
wndsrfr
looking for ideas. Mine is cut but it not large e... Dec 12 2014, 04:40 PM
pcar916 Wndsrfr, I'm afraid the plexiglass/lucite cove... Dec 12 2014, 06:39 PM
patssle Per firewall...if Porsche put a hole for the Boxst... Dec 12 2014, 10:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd September 2026 - 05:53 AM |
