| mepstein |
Dec 12 2014, 04:17 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,545 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
The only thing I know about suby transmissions is that I want one for my eg33 conversion. What model should I buy? What should I expect to pay, Where should I look? Blah, blah, blah.
Thanks in advance! |
| 76-914 |
Dec 12 2014, 06:16 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,870 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Read thru Chris and my build threads. That's all covered including clutch info.
| mepstein |
Dec 12 2014, 06:20 PM
| 76-914 |
Dec 12 2014, 08:32 PM
Read thru Chris and my build threads. That's all covered including clutch info. will do - who is chris Chris H. on here. He is the guy that responded to your earlier Suby post. Good guy and has done the EG33 conversion. Outside of our engine choice, tranny, and hydraulic clutch, we approached the conversions from different angles. I think you should look over every ones Suby build, augment and improve our methods for the next builder. When you have that tranny on the bench listen when shifting thru the gears. Reverse makes a distinctly different sound. You'll hear it. Helps in figuring out the shift pattern. Someone posted a Suby index............Britton ????? Sheez, I forget but it's bookmarked if you need it. Although there are a few more builds since that was started there is some very good info there. Enjoy the Challenge. (IMG:style_emoticons/default/beerchug.gif) |
mepstein Subaru conversion question Dec 12 2014, 04:17 PM
mgp4591 I'm using an automatic, but then I'm kinda... Dec 12 2014, 04:30 PM
JRust I believe you are going to want an 02-04 WRX trann... Dec 12 2014, 04:37 PM
I believe you are going to want an 02-04 WRX tran... Dec 12 2014, 04:59 PM
returf If you're going to develop the engine later on... Dec 12 2014, 06:23 PM
If you're going to develop the engine later o... Dec 12 2014, 06:39 PM
rnellums Pick the newest one you can find with the tallest ... Dec 12 2014, 09:04 PM
a914622 I am going with the late model cable shift 6 speed... Dec 13 2014, 10:03 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th March 2026 - 11:30 PM |
