how do I remove early /6 cam sprocket? |
tornik550 |
Dec 18 2014, 08:14 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
With the 46mm crowfoot tool and cam holder tool, I removed my camshaft nut. Took a lot of force but no big deal. In Wayne's book, it seems that the cam sprocket should just slide off once the cam nut is removed. Mine will not budge. Am I missing something?
rgalla9146 |
Dec 18 2014, 08:54 PM
Advanced Member Group: Members Posts: 4,563 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
There is a pin in one of the sprocket holes.
Put the nut back on hand tight. Rotate the engine to TDC. Remove the chain tensioner. Take the nut and wave washer back off. Use a spark plug as a tool (remove the threaded connector) to pull the pin out. Chain is now loose. Remove sprocket. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:52 PM |
