| got914? |
Dec 28 2014, 08:50 PM
Member ![]() ![]() Group: Members Posts: 133 Joined: 8-October 14 From: Niagara Member No.: 17,993 Region Association: None |
Hey everyone, just considering the above.
An LS1 is 350 hp and with the factory injection will both start and run like a dream. A real done up type 4 will sound much nicer but obviolsuy about a bit more than half the power. |
| Bruce Hinds |
Dec 29 2014, 10:53 AM
V-8 madness ![]() ![]() ![]() Group: Members Posts: 763 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
Wow . . .
Interesting that nobody actually mentioned that the V8 doesn't weigh that much more. I don't know how much lighter the LS is than the SBC, but the iron head and block SBC with all associated hardware only adds 250 lbs to the total car weight and the weight distribution is still 49/51%. It's no more than noticeable than taking a big friend for a ride. The purist will bark all day long about how you ruin the handling, and the need to go bigger wheels and brakes. I agree to some extent, but the modification don't have to be extreme. Drive one before you decide . . . |
| CptTripps |
Dec 29 2014, 11:44 AM
:: Punch and Pie :: ![]() ![]() ![]() ![]() Group: Members Posts: 3,585 Joined: 26-December 04 From: Tuscaloosa, AL and Akron, OH Member No.: 3,342 Region Association: Upper MidWest |
Wow . . . Interesting that nobody actually mentioned that the V8 doesn't weigh that much more. I don't know how much lighter the LS is than the SBC, but the iron head and block SBC with all associated hardware only adds 250 lbs to the total car weight and the weight distribution is still 49/51%. It's no more than noticeable than taking a big friend for a ride. The purist will bark all day long about how you ruin the handling, and the need to go bigger wheels and brakes. I agree to some extent, but the modification don't have to be extreme. The weight may not change all that much, but WHERE the weight is does effect the car. I bought my car with a SB350 and am changing to a Subie for this exact reason. (And the trans...and the turbo...and the other upgrades possible.) Drive one before you decide . . . Best advice so far. |
| mgp4591 |
Dec 30 2014, 02:21 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,908 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
Wow . . . Interesting that nobody actually mentioned that the V8 doesn't weigh that much more. I don't know how much lighter the LS is than the SBC, but the iron head and block SBC with all associated hardware only adds 250 lbs to the total car weight and the weight distribution is still 49/51%. It's no more than noticeable than taking a big friend for a ride. The purist will bark all day long about how you ruin the handling, and the need to go bigger wheels and brakes. I agree to some extent, but the modification don't have to be extreme. The weight may not change all that much, but WHERE the weight is does effect the car. I bought my car with a SB350 and am changing to a Subie for this exact reason. (And the trans...and the turbo...and the other upgrades possible.) Drive one before you decide . . . Best advice so far. Doug, SOT but I've never seen what they're using for the cradle on a V8... is it round or square tubing and approx. what size? I'll be making my own and I'd like a comparison. Thanks! |
| CptTripps |
Dec 30 2014, 12:00 PM
The weight may not change all that much, but WHERE the weight is does effect the car. I bought my car with a SB350 and am changing to a Subie for this exact reason. (And the trans...and the turbo...and the other upgrades possible.) Doug, SOT but I've never seen what they're using for the cradle on a V8... is it round or square tubing and approx. what size? I'll be making my own and I'd like a comparison. Thanks! Mine was a Renegade kit that was a square-tube cradle. The oil pan does go pretty low and close to the ground. The other issue is that the pan is quite tall, so the bulk of the block goes up quite a bit higher than the flat-4 motor. I can't stress this enough. DRIVE one before you make a decision. I've had a "hot 4" 914 before, and when I bought my latest car, it had a renegade V8 in it, along with the 4-speed modified 901. The handling is a bit different, and I'd hate for you to put a bunch of time/work into something, only to realize later it's not what you were hoping for. It WAS a lot of fun to drive, but sounded like an 80's Camaro. I just never really liked driving it as much as I did the 2.0 flat-4 I had in my 73. To get ahead of the haters: I went for the Subie conversion without driving one, but looking at the weight numbers was only part of my decision. The Subie trans and the turbo were my major points. Coupled with a large number of "upgrade" options, I was sold on the Subie. I'm VERY happy that I did the conversion, and I can't wait to have it completed in the coming months. If I had to do it over again, I'd got with a Subaru H6. Less expensive than a Porsche 6....by a lot. Lots of upgrade parts available. Plenty of support here to get you up and rolling quickly. Plenty of HP. Seems like the best of both worlds. My next 914 build (yes, I'm already planning another) will be a Subie H6. |
got914? LS1 or smokin hot type 4 ? Dec 28 2014, 08:50 PM
mgp4591 I'd think all that heat from a built up 4 is g... Dec 28 2014, 09:22 PM
Bruce Hinds They'd be different cars for sure.
I went the... Dec 28 2014, 10:02 PM
thelogo Yeah your not gonna ever find much that beat s the... Dec 28 2014, 10:07 PM
larryM depends on what you want to do with it
if you jus... Dec 28 2014, 10:09 PM
thelogo P c a Thats a laugh I though this was narp Dec 28 2014, 10:20 PM
Mark Henry To me once you go V8 you lost the whole point of o... Dec 28 2014, 10:46 PM
speed metal army
To me once you go V8 you lost the whole point of ... Dec 28 2014, 10:55 PM
mgp4591
To me once you go V8 you lost the whole point of ... Dec 29 2014, 04:32 AM
DBCooper "If you put a Ford V8 into an AC Ace you ruin... Dec 29 2014, 08:54 AM
Mark Garriott
To me once you go V8 you lost the whole point of ... Jan 2 2015, 01:01 PM
PotterPorsche If I wanted a v8 I would install in a boxster like... Dec 28 2014, 10:58 PM
Mike Bellis I think it's funny how so many are against V8 ... Dec 28 2014, 11:15 PM
CptTripps The V8 changes the weight dynamics of the car. You... Dec 29 2014, 08:28 AM
Mark Henry
The V8 changes the weight dynamics of the car. Yo... Dec 29 2014, 09:21 AM
jgara962 Put in a big Type 4. The car will have plenty of ... Dec 29 2014, 09:30 AM
DBCooper
Put in a big Type 4. The car will have plenty of... Dec 29 2014, 10:03 AM
jgara962
Put in a big Type 4. The car will have plenty o... Dec 29 2014, 10:08 AM
DBCooper
How many Cobras do you own?
Ha ha, I wish. But... Dec 29 2014, 10:34 AM
era vulgaris
Put in a big Type 4. The car will have plenty of... Dec 29 2014, 10:43 AM
DBCooper
But honestly if someone wants to chop up their ca... Dec 29 2014, 12:17 PM
era vulgaris
And that "mine will be worth more" thi... Dec 29 2014, 06:53 PM
sb914 Wow Dec 29 2014, 09:42 AM
GeorgeRud You'll never be disappointed with a -6 convers... Dec 29 2014, 09:54 AM
mgp4591 Lycoming? :confused: Continental?? :idea: Dec 29 2014, 09:58 AM
jmmotorsports
Wow . . .
Interesting that nobody actually menti... Jan 1 2015, 04:04 PM
andys
gm performance parts say 575 lbs for turnkey 350... Jan 1 2015, 04:36 PM
messix
gm performance parts say 575 lbs for turnkey 35... Jan 1 2015, 05:36 PM
madmax914 If you're wanting HP and handling than you rea... Dec 29 2014, 11:23 AM
JRust You would be amazed at how tame you can drive the ... Dec 29 2014, 11:36 AM
boxstr I have owned 5 914 v8 conversions. And I loved eve... Dec 29 2014, 11:55 AM
rnellums I did a subaru conversion on my 73 914 that had ac... Dec 29 2014, 12:32 PM
iamchappy Funny how so few recommend a Porsche flat 6, to me... Dec 29 2014, 12:43 PM
DBCooper
The 4 blew up..
Ha ha, that happened to you, me, ... Dec 29 2014, 01:21 PM
914_3.0 The last thing I would do is put a bowtie in my be... Dec 29 2014, 01:31 PM
DBCooper
The last thing I would do is put a bowtie in my b... Dec 29 2014, 02:33 PM
914_3.0
The last thing I would do is put a bowtie in my ... Dec 30 2014, 11:19 AM
Mark Henry
[quote name='DBCooper' post='2127639' date='Dec 2... Dec 30 2014, 11:28 AM
tooms351 A friend of mine ran a DE at Sebring this summer, ... Dec 29 2014, 02:29 PM
tooms351 DUH Dec 29 2014, 02:33 PM
messix wow!
the last bunch of comments here really d... Dec 29 2014, 08:04 PM
mgp4591
wow!
the last bunch of comments here really ... Dec 30 2014, 02:08 AM
Mark Henry Really relax guys, it's your car do what you w... Dec 29 2014, 08:07 PM
messix
Really relax guys, it's your car do what you ... Dec 29 2014, 08:15 PM
messix :beer2: Dec 29 2014, 08:15 PM
Rand LS.... what now? 3 or more? It's not cast iron... Dec 29 2014, 08:29 PM
Rand Ok, all this. Shall I repost what the OP asked? ... Dec 30 2014, 04:04 AM
DBCooper Yeah, I've been driving a 914/Subaru for a whi... Dec 30 2014, 11:55 AM
Mark Henry
Yeah, I've been driving a 914/Subaru for a wh... Dec 30 2014, 12:02 PM
DBCooper Oh crap, it's too late for Christmas now and t... Dec 30 2014, 12:06 PM
r_towle I have an audi a8 with a 4.2 liter OVERHEAD camsha... Dec 30 2014, 04:58 PM
BIGKAT_83
I have an audi a8 with a 4.2 liter OVERHEAD camsh... Dec 30 2014, 05:20 PM
r_towle
I have an audi a8 with a 4.2 liter OVERHEAD cams... Dec 30 2014, 05:43 PM
cali914 The 914 is a great car whether it has a subie, LS,... Dec 30 2014, 05:49 PM
got914?
I am all for people trying different engine combi... Dec 30 2014, 05:55 PM
Mueller What is your expected budget and time frame?
Look... Dec 30 2014, 06:08 PM
thelogo http://m.chevrolet.com/performance/crate-e...ml#.V... Dec 30 2014, 09:31 PM
Cracker It greatly depends upon your goals and objectives ... Dec 30 2014, 10:14 PM
rdauenhauer Hmmm ...good debate. Im one of those "few... Dec 30 2014, 11:54 PM
Mueller
Hmmm ...good debate. Im one of those "few... Dec 31 2014, 01:07 AM
returf my wife would be ok with a big 6 but unfortunately... Dec 31 2014, 04:19 AM
mgp4591
my wife would be ok with a big 6 but unfortunatel... Dec 31 2014, 05:02 AM
r_towle
my wife would be ok with a big 6 but unfortunatel... Dec 31 2014, 07:33 AM
Cracker More taste (power) - less filling (weight)! ;-... Jan 1 2015, 04:18 PM
Steve
More taste (power) - less filling (weight)! ;... Jan 1 2015, 09:57 PM
Cracker Glad to help Steve...a book called "Porsche 9... Jan 1 2015, 10:28 PM
Mark Henry
More taste (power) - less filling (weight)! ;... Jan 2 2015, 08:25 AM
Cracker Mark - I'm very happy for you. Really though -... Jan 2 2015, 09:53 AM
Mark Henry
Mark - I'm very happy for you. Really though ... Jan 2 2015, 10:48 AM
got914?
Mark - I'm very happy for you. Really though... Jan 2 2015, 11:20 AM
Cracker Don't be so thin-skinned my Northern enthusias... Jan 2 2015, 11:23 AM
thelogo Just curious is anyone doing a straight or v 6
I... Jan 1 2015, 09:18 PM
Bruce Hinds
... Jan 2 2015, 12:23 AM
CG-914 V8 is cheap power but not as refined as Porsche ty... Jan 1 2015, 09:25 PM
Bruce Hinds
V8 is cheap power but not as refined as Porsche t... Jan 2 2015, 12:17 AM
computers4kids My complete SBC conversion with AC added 250lbs. ... Jan 2 2015, 11:02 AM
Mike Bellis I have had several conversions, each one a little ... Jan 2 2015, 02:57 PM
DBCooper That's a pretty good perspective. You can hav... Jan 2 2015, 04:10 PM
era vulgaris
To address the "but it's not a 914 anym... Jan 3 2015, 08:32 AM
DBCooper Exactly. The question is how the car performs, bo... Jan 3 2015, 10:08 AM
jgara962
I get what you're saying. You keep using th... Jan 3 2015, 11:39 AM
Cracker
I wonder what percentage of similar vintage cars... Jan 3 2015, 06:36 PM
john77 http://www.914world.com/bbs2/uploads_offsite/www.c... Jan 3 2015, 09:14 PM
v82go I have owned 9 or 10 type 4 powered 914s, one co... Jan 2 2015, 06:17 PM
Mark Henry
Also when comparing weights, lets not forget ab... Jan 3 2015, 08:41 AM
Cracker Again, as I stated in a previous post, weight is a... Jan 3 2015, 09:23 AM
Steve I couldn't agree more. I had a big 4, didn... Jan 3 2015, 11:28 AM
rnellums
Curious about the other politics. Does PCA allow... Jan 3 2015, 11:41 AM
Cracker The old-er stock (pre-2004) LS1's redline at 6... Jan 3 2015, 11:44 AM
Maltese Falcon
The old-er stock (pre-2004) LS1's redline at ... Jan 3 2015, 01:18 PM
Cracker Awesome! I'd very much like to see the bui... Jan 3 2015, 04:15 PM
messix :deadhorse: Jan 3 2015, 11:53 AM
Mike Bellis I was raised a Hot Rodder. I don't see any pro... Jan 3 2015, 12:17 PM
BuddyV
I was raised a Hot Rodder. I don't see any pr... Jan 3 2015, 01:34 PM
drive-ability I think they are two totally different animals.(LS... Jan 3 2015, 04:39 PM
messix the Ls engine is "the engine" to transpl... Jan 3 2015, 07:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:43 PM |
