microsa |
Member ![]() ![]() Group: Members Posts: 94 Joined: 20-February 03 From: San Antonio, Tx Member No.: 329 ![]() |
O.K. I'm getting ready to do the 5 lug conversion on YellowDog. I have a 68 SC front end and I am going to re-drill the rear hubs. The question is what do you that have done this recommend; press in studs or bolts? If studs, where did you source them and if bolts, how long? I have a set of BBS style wheels that came off a 68 SC 'I think'. Also if I go with studs, will I need to machine a 'flat' on the back side of the hub so they seat?
RAR |
Member ![]() ![]() Group: Members Posts: 189 Joined: 24-January 04 From: Washington state Member No.: 1,598 ![]() |
SC has aluminum I beam crossmember. May have started a little earlier. The 911S (early 70's) had 3.5" caliper spacing.
On the rear, the early911 (same as 914-6 I believe) hub and CV is splined same as the 914-4 axle. Save the rear parts, as with parts from the 944 you can do the entire rear to five lug, brakes too I believe. My memory is a little vague on the exact combination. |
Lo-Fi Version | Time is now: 3rd July 2025 - 11:59 AM |
