| DougC |
Aug 27 2004, 08:53 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
Anyone here know how to remove the pulley and dampner assembly on the front crank? This one does not have a visible bolt (inside the assembly). It's a SBC 283 that was original to 1960. Also has rivets (kind of) that attach the pulley to the dampner so I assume they come off together with a big puller maybe? An engine building book I have says that some motors came this way but doesn't give procedures for removal in this case..all help would be greatly appreciated!
Doug C |
| cametal |
Aug 28 2004, 12:17 AM
autox'n ![]() ![]() Group: Members Posts: 76 Joined: 28-July 03 From: Oklahoma City, OK. Member No.: 960 |
You will need to remove the pulley then use a harmonic balancer puller (it uses the pulley bolt holes) to remove the dampner. You should drill and tap the crank for a bolt. The older SBC didn't have a center bolt. I threw the whole setup off a older 327 that didn't have one. (IMG:style_emoticons/default/ohmy.gif)
DougC V8 disassimbly - help Aug 27 2004, 08:53 AM
neo914-6 I have not seen a pulley type that was not bolted.... Aug 27 2004, 09:53 PM
Verruckt Pully should be bolted to the damper. The damper s... Aug 28 2004, 12:13 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 07:19 PM |
