> engine swap , anything smaller then a type 4, goal being 100hp ,smallest engine possible
thelogo
post Jan 6 2015, 11:53 PM
Group: Retired Members
I'm desperate to ditch the 1.7
But not looking to shoehorn anything huge in there
I'd prefere to have a simple install with plenty of room to spare
I figured that the smallest engine possible would be an advantage
So are there any tiny boxer Subaru motors
Or
Something that fits better then others
And please weigh in
Advantage and disadvantage
Subaru conversion vs. Big type 4 (IMG:style_emoticons/default/WTF.gif)
Dave_Darling
post Jan 8 2015, 10:38 AM
914 Idiot
The 1.7 is probably the most robust of all of the 914 engines. We know of examples that go well over 200K miles without being touched. (Though many of those start using copious amounts of oil near the end.)
The heads are less prone to cracking than the 2.0 ones, the crank is stiffer because it has thicker rod journals than the 2.0 (or other stroker) cranks, and they tend to be less stressed over all.
If you don't like D-jet, you can put together a Megasquirt or Microsquirt system for not much money--but you'll have to spend time and effort (and some $) setting it up and tweaking it. Or you can slap a set of dual carbs on and tinker with them. Either way is going to be much simpler than working out how to fit a modern fuel injected water-cooled engine.
That said, if you want Scooby power, go Scooby power!
--DD
thelogo   engine swap , anything smaller then a type 4   Jan 6 2015, 11:53 PM
porschefile2010   You can get some pretty impressive horsepower from...   Jan 7 2015, 12:11 AM
Alphaogre   You can get some pretty impressive horsepower fro...   Jan 7 2015, 12:30 AM
Alphaogre   Cam, heads, bore and stroke. Through enought money...   Jan 7 2015, 12:26 AM
damesandhotrods   If a 100 hp would make you happy, why worry about ...   Jan 7 2015, 04:39 AM
Chris H.   Subaru and Type 4 are pretty much the same size. ...   Jan 7 2015, 08:54 AM
veekry9   The blower solves the torque curve. [url=http:/...   Jan 7 2015, 09:09 AM
Dave_Darling   Simple install? Build up your 1.7 to get the powe...   Jan 7 2015, 12:46 PM
SirAndy   Simple install? Build up your 1.7 to get the powe...   Jan 7 2015, 01:32 PM
GeorgeRud   Mazda rotary if you want small and something that ...   Jan 7 2015, 12:54 PM
Mueller   Smaller motor usually means less torque and higher...   Jan 7 2015, 02:20 PM
r_towle   if your heart is set on getting rid of the 1.7 mot...   Jan 7 2015, 02:26 PM
Dave_Darling   Maybe we should ask what you mean by "small...   Jan 7 2015, 04:53 PM
thelogo   Maybe we should ask what you mean by "small...   Jan 7 2015, 10:04 PM
thelogo   Really I'm going for reliability and the 1.7 h...   Jan 7 2015, 08:51 PM
thelogo   And yeh as mentioned in previous post I would th...   Jan 7 2015, 09:40 PM
mr2by4   Any number of modern 4 cylinder water cooled motor...   Jan 7 2015, 09:46 PM
thelogo   I personally like the transmission and don't i...   Jan 7 2015, 09:57 PM
brant   Stupid thread   Jan 7 2015, 10:01 PM
infraredcalvin   Buy this... http://forums.pelicanparts.com/porsch...   Jan 7 2015, 10:04 PM
mgp4591   Buy this... http://forums.pelicanparts.com/porsc...   Jan 7 2015, 10:22 PM
bakerj   [quote name='infraredcalvin' post='2131495' date=...   Jan 8 2015, 11:00 AM
infraredcalvin   Whoops, should have know to check here first, bett...   Jan 7 2015, 10:06 PM
thelogo   Whoops, should have know to check here first, bet...   Jan 7 2015, 10:35 PM
thelogo   Aggreed this is stupid That the ideal replacement ...   Jan 7 2015, 10:09 PM
brant   Aggreed this is stupid That the ideal replacement...   Jan 7 2015, 10:19 PM
thelogo   Actually yeh , I never though 3 cylinder but if th...   Jan 7 2015, 10:24 PM
Mueller   Actually yeh , I never though 3 cylinder but if t...   Jan 8 2015, 09:52 AM
The Cabinetmaker   Your views on the 1.7 are totally wrong. My first ...   Jan 8 2015, 09:00 AM
thelogo   Ok I stand corrected , if the 1.7 Can hack it th...   Jan 8 2015, 09:43 AM
Dave_Darling   The 1.7 is probably the most robust of all of the ...   Jan 8 2015, 10:38 AM
Mueller   The 1.7 is probably the most robust of all of the...   Jan 8 2015, 11:29 AM
thelogo   I don't mind d.jet but There are extremely f...   Jan 8 2015, 11:11 AM
DBCooper   And I'm not even technically proficient enough...   Jan 12 2015, 04:05 PM
The Cabinetmaker   And I'm not even technically proficient enoug...   Jan 12 2015, 04:18 PM
DBCooper   Seriously DB? A guy can't change a headlight ...   Jan 12 2015, 05:36 PM
veekry9   [url=http://www.ebay.com/itm/1992-92-Harley-Sprin...   Jan 8 2015, 11:53 AM
veekry9   20K brand new. :blink: [url=http://thekneeslid...   Jan 11 2015, 09:53 AM
scotty b   Meets all your criteria. It's small, nimble, s...   Jan 11 2015, 10:01 AM
thelogo   Meets all your criteria. It's small, nimble, ...   Jan 11 2015, 10:18 AM
blabla914   The good news is a 1.7 is almost impossible to kil...   Jan 11 2015, 03:31 PM
brant   Maybe. You need to learn how to work on it or buy ...   Jan 11 2015, 05:04 PM
thelogo   Hey they told me to get in the car and drive and I...   Jan 11 2015, 06:15 PM
brant   Hey they told me to get in the car and drive and ...   Jan 11 2015, 07:27 PM
thelogo   Hey they told me to get in the car and drive and...   Jan 11 2015, 11:15 PM
era vulgaris   I don't know I always thought this car was t...   Jan 12 2015, 06:52 PM
veekry9   I will continue looking into the Valkrie 6 and how...   Jan 11 2015, 07:32 PM
veekry9   tGZu20w5xwYhttp://en.wikipedia.org/wiki/Honda_Valk...   Jan 12 2015, 02:37 PM
thelogo   I'm not trying to defend my lack of mechanical...   Jan 12 2015, 04:22 PM
Dave_Darling   Realistically, any older car is going to have trou...   Jan 12 2015, 05:12 PM
veekry9   Amazing to me a WestCoaster has no autoskill. Ever...   Jan 12 2015, 08:02 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:35 AM
