> Weber rebuilding, tell me something
Trekkor
post Aug 20 2004, 10:38 PM
I do things...
I'll be rebuilding the carbs on my SIX next week.
I wonder if I should do internal baffling while they're open.
What are the benefits to this mod? Perry, Gint, JP, Brad, Lawrence, Sean, Root?
Any other advice ( besides keeping the four ) would be appreciated.
KT
Trekkor
post Aug 28 2004, 10:21 PM
I do things...
Carbs are back on the SIX.
Started instantly. High Idle. Tuned it down. Good. (IMG:style_emoticons/default/clap56.gif)
Problem is this: I think the float level adjustment is wrong on one bank.
Fuel is leaking out around the base.
I turned the fuel PSI down to 2.5 but it still dribbles.
I guess I'll pop the top and bend the tab up a scoaschie.
The rebuild kit came with new fuel inlet needle valves.
The length of them may be a hair shorter or the washers thicker not allowing the fuel to shut off when the bowl is full. (IMG:style_emoticons/default/confused24.gif)
I have to set the a/f after the flood is over.
KT
trekkor   Weber rebuilding   Aug 20 2004, 10:38 PM
McMark   Yes, you should, it's easy and fairly quick. ...   Aug 20 2004, 10:51 PM
trekkor   Soooo....tell all. KT   Aug 20 2004, 10:54 PM
J P Stein   I've never had the need for the baffle mod (th...   Aug 20 2004, 10:56 PM
!   THROTTLE SHAFTS...HOW ARE THEY?   Aug 20 2004, 10:56 PM
Eric_Shea   :agree: with JP   Aug 20 2004, 10:59 PM
McMark   I'm worried about the throttle shafts as well....   Aug 21 2004, 12:27 AM
ArtechnikA   you've got a SIX now, you need to go buy more ...   Aug 21 2004, 06:42 AM
Gint   :agree: with all of the above. 'Specially J...   Aug 21 2004, 08:50 AM
J P Stein   Bout this tall :D   Aug 21 2004, 03:31 PM
J P Stein   I've never been able to tell fer sure that the...   Aug 21 2004, 03:49 PM
Eric_Shea   ToB... thing of beauty :trophy: Even the engine...   Aug 21 2004, 04:21 PM
Gint
  Aug 21 2004, 07:38 PM
trekkor   The carbs are off the motor and in my shed now. I...   Aug 21 2004, 08:56 PM
J P Stein   I don't say "no". I said I haven't needed...   Aug 21 2004, 10:53 PM
trekkor   JP, I guess what I'm asking is, "Do I need it?...   Aug 21 2004, 11:08 PM
ArtechnikA   <...   Aug 22 2004, 06:37 AM
J P Stein   :agree: Rich has said it better than I could....w...   Aug 22 2004, 07:52 AM
trekkor   Rich, JP, I can see that these Weber dance lesson ...   Aug 22 2004, 09:11 AM
trekkor   O.K.- tonight's the night. I'm going out ...   Aug 23 2004, 07:31 PM
trekkor   ready...   Aug 23 2004, 09:08 PM
trekkor   clean and scattered... one down :) KT   Aug 23 2004, 09:15 PM
Brad Roberts   What size are the venturi's ?? That will tell ...   Aug 23 2004, 09:49 PM
trekkor   30's on the venturi's. I'd be happy w...   Aug 23 2004, 11:18 PM
Brad Roberts   30mm ?? Stock 9146 2.0 was something like 28mm and...   Aug 23 2004, 11:36 PM
trekkor   Brad, 180 on the emulsion tube top jet and 55 idle...   Aug 23 2004, 11:48 PM
trekkor   Carbs are back on the SIX. Started instantly. Hig...   Aug 28 2004, 10:21 PM
!   WARNING...thread hijack...... Took Frank out for ...   Aug 28 2004, 10:37 PM
trekkor   *THREAD RECOVERY* I'll start by removing the ...   Aug 28 2004, 11:08 PM
Gint   3.5 I think. And IIRC, you are suppposed to shim ...   Aug 28 2004, 11:16 PM
trekkor   Thanks, Mike. How's the tub? KT   Aug 28 2004, 11:38 PM
Gint   Sittin around at the moment.   Aug 28 2004, 11:41 PM
McMark   WTF Trekkor. You're too good for me now, is t...   Aug 29 2004, 01:47 AM
trekkor   Mark, easy...you're the best. :boing: Engine...   Aug 29 2004, 09:42 AM
McMark   Oops, I forgot my last emoticon on that message......   Aug 29 2004, 01:19 PM
trekkor   Fuel leak is gone now due to the fact that *someon...   Sep 2 2004, 10:22 PM
Gint   Trekkor, Try this. Mid-Engine Views Weber articl...   Sep 3 2004, 08:23 AM
Root_Werks   Good job on the carbs! :D Your venruries a...   Sep 3 2004, 09:39 AM
trekkor   Thanks, Brad and Rich. Now I have the sync and flo...   Sep 22 2004, 06:47 PM
Carl
  Sep 22 2004, 11:56 PM
trekkor   The article was very easy to understand. Thanks ag...   Sep 27 2004, 07:32 PM
Gint   I corrected the link title after reading Carl...   Sep 27 2004, 07:52 PM
- Lo-Fi Version Time is now: 16th July 2025 - 04:18 PM
