| Hank914 |
Jan 11 2015, 11:46 AM
Member ![]() ![]() Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
I have a tranny case leak that needs a repair. Here is a pic of the leak, which when warmed up is about one large drop a second.
I figure that I should do a real weld for the permanent fix, but would like to do a temp fix so I can drive over to my welder brother-in law about a 100 miles away. So, what is the best liquid weld goop for this type of a hole (about 1-2 mm in diameter)? |
| Mike Bellis |
Jan 11 2015, 12:18 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Drill it, tap it and install a plug.
Or Find a new transmission... |
| SirAndy |
Jan 11 2015, 02:03 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,458 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Drill it, tap it and install a plug. (IMG:style_emoticons/default/agree.gif) In addition to that i would also ask myself how the heck did that hole get there in the first place. (IMG:style_emoticons/default/shades.gif) |
Hank914 Liquid welds on the tranny case Jan 11 2015, 11:46 AM
Hank914 Here is a somewhat in focus close up of the hole.
... Jan 11 2015, 11:53 AM
Harpo Your trans case is magnesium. Good luck
David Jan 11 2015, 12:15 PM
Hank914
Thanks for... Jan 11 2015, 12:35 PM
Mike Bellis
Thanks fo... Jan 11 2015, 12:47 PM
jd74914
If the case is magnesium, you will not be able to... Jan 11 2015, 04:10 PM
Bruce Hinds It would be a no brainer to try the JB weld.
I... Jan 11 2015, 03:50 PM
veekry9 Welding is possible,but,the damaged area will requ... Jan 11 2015, 05:10 PM
partwerks I used JB weld on a old 30+ year old, Campbell Ha... Jan 11 2015, 07:42 PM
veekry9 Oh yeah,I used the stuff for similar repairs,indis... Jan 11 2015, 07:59 PM
a few loose screws I'm another vote for installing a plug. As a s... Jan 12 2015, 06:32 AM
Geezer914 If the hole is small, say 1/8" just run a sm... Jan 12 2015, 07:09 AM
johnhora I've used JB Weld on 911 mag intake manifolds ... Jan 12 2015, 10:53 AM
veekry9 http://solutions.3m.com/wps/portal/3M/en_U...81606... Jan 12 2015, 11:17 AM
iamchappy JB Weld will work fiine, it's whats used on th... Jan 12 2015, 11:25 AM
Dr Evil A little back story...
This is the replacement tr... Jan 12 2015, 11:41 AM
Hank914
This is the replacement t... Jan 20 2015, 01:37 AM
Cap'n Krusty Every one of these solutions, except maybe drillin... Jan 12 2015, 11:45 AM
Dr Evil I can verify, but a 1/8" or slightly bigger p... Jan 12 2015, 11:56 AM
a few loose screws You can patch a leaking case without getting it pe... Jan 12 2015, 12:17 PM
CatDaddy60 I have a Case that ran afoul of a wayward axle sha... Jan 13 2015, 06:27 PM
Dr Evil For a small spot like Hank's, no prob to just ... Jan 13 2015, 07:49 PM
relentless One more tip if you do drill and tap it. Coat the... Jan 14 2015, 04:24 PM
Hank914 Thanks everybody for the comments and advice.
I w... Jan 18 2015, 08:18 PM
Dr Evil Looks great ;) Jan 18 2015, 08:21 PM
Hank914 Pic after my repair job. I screwed in a metal scr... Jan 18 2015, 08:22 PM
Dr Evil Did it work? If it gives you issues, change to NPT... Jan 18 2015, 08:28 PM
Hank914 And then I had to go have a few :beer3: while i... Jan 18 2015, 08:29 PM
Hank914 So yes, there is some yellow, which is oil. But m... Jan 18 2015, 08:30 PM
Dr Evil Ya, that is why they use pipe tread on the plugs, ... Jan 18 2015, 09:53 PM
Tbrown4x4 Mike, I was just about to PM you about Hank914... Jan 19 2015, 04:53 AM
sixnotfour
Send him a new one one Jan 20 2015, 02:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 02:11 AM |
