New shifter... |
New shifter... |
Mugs914 |
Dec 30 2014, 01:58 PM
"Hey, yellow IS faster!" Group: Members Posts: 618 Joined: 22-July 05 From: Temple TEXAS Member No.: 4,452 Region Association: Southwest Region |
One nice thing about Christmas time is that things slow down a bit around the shop and you might just be able to get something done on your OWN car!
I actually had some time to get this shifter fabbed up and installed. Not prettied up yet, but the functional bits are all done. The stick is custom made and is mounted on a short throw bottom end. The pivot base is stock with those extra stiff first-reverse lock out springs in it. I got rid of the stock shift coupler and replaced it with an Apex joint that fits just inside the firewall. The rear rod is a stock four cyl shift rod with a 3/4" diameter extension so that it extends through a pivot bearing mounted to the firewall and up to the Apex joint in the tunnel. The stock forward shift rod was shortened and a 3/4" plug welded in to mate up to the Apex joint. The result is REALLY crisp and the throws are really short (about 3.5" 2nd to 3rd), but of course it does take a bit more oompf to shift. Looks like I'll be going through gloves a little quicker! Happy New Year, by the way! Mike (Man, the pics really show up how filthy this poor thing is!) Attached thumbnail(s) |
McMark |
Dec 31 2014, 11:08 AM
Nice standoff. I'll be curious to hear your driving experiences. It's commonly said that 901's don't like quick shifts.
Also, watch out for this rubbing. Attached image(s) |
Randal |
Dec 31 2014, 02:10 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Nice standoff. I'll be curious to hear your driving experiences. It's commonly said that 901's don't like quick shifts. Also, watch out for this rubbing. 901's hate fast shifting. That's why I am using a stock shifter with the Foley rear setup. Give those syncro's time to mesh, otherwise you will crunch them. |
Mugs914 |
Dec 31 2014, 07:32 PM
901's hate fast shifting. That's why I am using a stock shifter with the Foley rear setup. Give those syncro's time to mesh, otherwise you will crunch them. Not trying to shift it like a Hewland, I just like short throws in the race car and having the shifter up near the wheel. Its pretty smooth actually, in spite of the short throws. Nice catch Mark! I'll have to get something in there to shield that cable. Mike |
Randal |
Jan 1 2015, 10:45 AM
901's hate fast shifting. That's why I am using a stock shifter with the Foley rear setup. Give those syncro's time to mesh, otherwise you will crunch them. Not trying to shift it like a Hewland, I just like short throws in the race car and having the shifter up near the wheel. Its pretty smooth actually, in spite of the short throws. Nice catch Mark! I'll have to get something in there to shield that cable. Mike I think on the track it's easier to shift with a reasonable cadence and not tear up the 901. Autoxing on the other hand is exactly the opposite as every MS counts, so easy to forget cadence and just get more aggressive with the shifter. (IMG:style_emoticons/default/w00t.gif) Like the idea of having the shifter closer to you right hand, i.e., up high. And your fabrication is cool. |
Mugs914 |
Jan 11 2015, 06:44 PM
I think on the track it's easier to shift with a reasonable cadence and not tear up the 901. Autoxing on the other hand is exactly the opposite as every MS counts, so easy to forget cadence and just get more aggressive with the shifter. (IMG:style_emoticons/default/w00t.gif) Like the idea of having the shifter closer to you right hand, i.e., up high. And your fabrication is cool. Thanks! Agree about autocross; Mr. Hyde emerges and you start getting 'grabby'! Of course there are some guys who lose control on the track as well. I've got a buddy who we call 'Chevelle' because he gets excited and starts trying to slam shift his Spec 944 like a drag racer. His new gearbox is almost finished... (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 29th May 2024 - 04:18 AM |
