> Liquid welds on the tranny case, JB Weld, Permatex Gear Oil RTV Gasket Maker, ??
Hank914
post Jan 11 2015, 11:46 AM
I have a tranny case leak that needs a repair. Here is a pic of the leak, which when warmed up is about one large drop a second.
I figure that I should do a real weld for the permanent fix, but would like to do a temp fix so I can drive over to my welder brother-in law about a 100 miles away.
So, what is the best liquid weld goop for this type of a hole (about 1-2 mm in diameter)?
a few loose screws
post Jan 12 2015, 06:32 AM
I'm another vote for installing a plug. As a side note, anyone interested should check out the devcon line of products for all your liquid weld and patch job needs. It's the real deal, all good stuff. They have epoxies with stainless steel, aluminum, titanium, ceramic and bronze. They have a good quick patch for emergencies called fastmetal. I've used it personally on a cracked wheel loader transmission case, good temporary fix.
Hank914   Liquid welds on the tranny case   Jan 11 2015, 11:46 AM
Hank914   Here is a somewhat in focus close up of the hole. ...   Jan 11 2015, 11:53 AM
Harpo   Your trans case is magnesium. Good luck David   Jan 11 2015, 12:15 PM
Mike Bellis   Drill it, tap it and install a plug. Or Find a n...   Jan 11 2015, 12:18 PM
Hank914   Drill it, tap it and install a plug. Thanks for...   Jan 11 2015, 12:35 PM
Mike Bellis   Drill it, tap it and install a plug. Thanks fo...   Jan 11 2015, 12:47 PM
jd74914   If the case is magnesium, you will not be able to...   Jan 11 2015, 04:10 PM
SirAndy   Drill it, tap it and install a plug. :agree: I...   Jan 11 2015, 02:03 PM
Bruce Hinds   It would be a no brainer to try the JB weld. I...   Jan 11 2015, 03:50 PM
veekry9   Welding is possible,but,the damaged area will requ...   Jan 11 2015, 05:10 PM
partwerks   I used JB weld on a old 30+ year old, Campbell Ha...   Jan 11 2015, 07:42 PM
veekry9   Oh yeah,I used the stuff for similar repairs,indis...   Jan 11 2015, 07:59 PM
a few loose screws   I'm another vote for installing a plug. As a s...   Jan 12 2015, 06:32 AM
Geezer914   If the hole is small, say 1/8" just run a sm...   Jan 12 2015, 07:09 AM
johnhora   I've used JB Weld on 911 mag intake manifolds ...   Jan 12 2015, 10:53 AM
veekry9   http://solutions.3m.com/wps/portal/3M/en_U...81606...   Jan 12 2015, 11:17 AM
iamchappy   JB Weld will work fiine, it's whats used on th...   Jan 12 2015, 11:25 AM
Dr Evil   A little back story... This is the replacement tr...   Jan 12 2015, 11:41 AM
Hank914   A little back story... This is the replacement t...   Jan 20 2015, 01:37 AM
Cap'n Krusty   Every one of these solutions, except maybe drillin...   Jan 12 2015, 11:45 AM
Dr Evil   I can verify, but a 1/8" or slightly bigger p...   Jan 12 2015, 11:56 AM
a few loose screws   You can patch a leaking case without getting it pe...   Jan 12 2015, 12:17 PM
CatDaddy60   I have a Case that ran afoul of a wayward axle sha...   Jan 13 2015, 06:27 PM
Dr Evil   For a small spot like Hank's, no prob to just ...   Jan 13 2015, 07:49 PM
relentless   One more tip if you do drill and tap it. Coat the...   Jan 14 2015, 04:24 PM
Hank914   Thanks everybody for the comments and advice. I w...   Jan 18 2015, 08:18 PM
Dr Evil   Looks great ;)   Jan 18 2015, 08:21 PM
Hank914   Pic after my repair job. I screwed in a metal scr...   Jan 18 2015, 08:22 PM
Dr Evil   Did it work? If it gives you issues, change to NPT...   Jan 18 2015, 08:28 PM
Hank914   And then I had to go have a few :beer3: while i...   Jan 18 2015, 08:29 PM
Hank914   So yes, there is some yellow, which is oil. But m...   Jan 18 2015, 08:30 PM
Dr Evil   Ya, that is why they use pipe tread on the plugs, ...   Jan 18 2015, 09:53 PM
Tbrown4x4   Mike, I was just about to PM you about Hank914...   Jan 19 2015, 04:53 AM
sixnotfour   Send him a new one one   Jan 20 2015, 02:06 AM
- Lo-Fi Version Time is now: 14th March 2026 - 02:12 AM
