Late Model Fuel Pump Mounting Plate, Looking for pictures of the mount and orientation |
Nozzle |
Jan 12 2015, 06:27 PM
Member Group: Members Posts: 158 Joined: 6-November 08 From: Lexington Park, Maryland Member No.: 9,725 Region Association: MidAtlantic Region |
I am interested in mounting a new fuel pump in the late model forward location using the stock mounting bracket and plate. I've tried to find good pictures online and using the search function here to use as a reference but so far no luck.
Any help would be much appreciated. Thanks. |
Spoke |
Jan 12 2015, 07:19 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Here's how I mounted the fuel pump in the front.
Cut the fuel door by outlining the cutout with spray paint Welded a plate onto the cutout so the cutout centers the cover. Drilled holes for bolts. Welded nuts onto the inside of the fuel tank area. Used 2 hose clamps to secure the pump to the door. Dremel made some nice slots to run the clamps through. Offset the pump on the door so I could pull the pump out easily. Done. |
Lo-Fi Version | Time is now: 6th June 2024 - 10:12 AM |
