| sgomes |
Aug 29 2004, 02:24 PM
Electric Member ![]() ![]() ![]() Group: Members Posts: 815 Joined: 6-May 04 From: Campbell, CA Member No.: 2,029 |
Just a few progress pics for the curious. It's not a huge amount of progress but at least it feels like the project is starting to move forward! (IMG:style_emoticons/default/smilie_pokal.gif)
This is a pic of the taper lock hub. It's the reason for my question about flywheel distance. I have about 5 cm of play here so I needed to know where the flywheel was SUPPOSED to end up. Thank you Demick for the fantastic data dump you gave me! (IMG:style_emoticons/default/pray.gif) The amazing thing about taper lock hubs is that you can remove the bolts completely and the thing still won't come off! Attached image(s)
| Aaron Cox |
Aug 29 2004, 02:43 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
wow!...
now what do u use as final drive ratio... just 5th gear? whats the torque on that e motor? |
sgomes It's not much but it is FORWARD progress! Aug 29 2004, 02:24 PM
sgomes Flywheel: Demick -- the final distance was 44.2mm Aug 29 2004, 02:25 PM
Brad Roberts Cool. So you can use a stock flywheel/pp/disc setu... Aug 29 2004, 02:25 PM
sgomes Now THIS is how to spin up a motor on the bench... Aug 29 2004, 02:26 PM
Brad Roberts Ha ha.. we both posted at the exact same time.. TW... Aug 29 2004, 02:26 PM
sgomes Brad, yep it's stock all the way. Ok, I didn... Aug 29 2004, 02:27 PM
sgomes Oh and just cuz... here is the P. Plate: Aug 29 2004, 02:29 PM
sgomes This time for sure.. Aug 29 2004, 02:29 PM
sgomes Comparing gas engines to electric motors is always... Aug 29 2004, 02:57 PM
Brando is there any shifting with an electric motor car? ... Aug 29 2004, 03:07 PM
sgomes When you let off the pedal the motor doesn't s... Aug 29 2004, 03:12 PM
Aaron Cox
Brando how do you engine-brake? Aug 29 2004, 03:23 PM
Rhodes71/914 That's very cool, an electric engine in a 914.... Aug 29 2004, 03:35 PM
sgomes In MY setup I don't engine-brake at all. Yes ... Aug 29 2004, 03:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 10:21 PM |
