| opera guy |
Aug 29 2004, 03:02 PM
Member ![]() ![]() Group: Members Posts: 337 Joined: 28-June 04 From: upland, ca Member No.: 2,268 |
following the article on PP's site, i began to adjust my valves yesterday.
after i found TDC and begin to work on cylinder #1. i took out nut on the intake, and removed the valve adjustment screw to inspect for pitting. the screw looked fine so i put it back in. somehow, the screw wont go back to its prior location. i was only able to screw it in about 6-8 turns. I am positive im not cross-threading it. i think the valve popped out (closed inside the combustion chamber). how do i push the valve INTO the combustion chamber so i can continue threading the valve adjustment screw in and continue to do my adjustment? please tell me i didnt bent a valve, please!! |
| SpecialK |
Aug 29 2004, 03:08 PM
aircraft surgeon ![]() ![]() ![]() ![]() Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
kinda sounds like your push-rod isn't seated down in the lifter/tappet. Wiggle the push-rod around see if that gets you the clearance needed.
opera guy valve adjustment Aug 29 2004, 03:02 PM
Aaron Cox shouldnt be any load on the rocker when your worki... Aug 29 2004, 03:04 PM
nebreitling are you SURE that you were at TDC? Aug 29 2004, 03:28 PM
opera guy ![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 07:16 PM |
