| sgomes |
Aug 29 2004, 02:24 PM
Electric Member ![]() ![]() ![]() Group: Members Posts: 815 Joined: 6-May 04 From: Campbell, CA Member No.: 2,029 |
Just a few progress pics for the curious. It's not a huge amount of progress but at least it feels like the project is starting to move forward! (IMG:style_emoticons/default/smilie_pokal.gif)
This is a pic of the taper lock hub. It's the reason for my question about flywheel distance. I have about 5 cm of play here so I needed to know where the flywheel was SUPPOSED to end up. Thank you Demick for the fantastic data dump you gave me! (IMG:style_emoticons/default/pray.gif) The amazing thing about taper lock hubs is that you can remove the bolts completely and the thing still won't come off! Attached image(s)
| Aaron Cox |
Aug 29 2004, 03:14 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
QUOTE(Brando @ Aug 29 2004, 02:07 PM) is there any shifting with an electric motor car? I've always wondered... since when you let off the power, the engine stops spinning, wouldn't that make for grinding gears? good point. electric motors develop most of their power and torque at low rpm's right? so i thought you just start in whatevr gear youd like....and vary the current for more or less speed |
sgomes It's not much but it is FORWARD progress! Aug 29 2004, 02:24 PM
sgomes Flywheel: Demick -- the final distance was 44.2mm Aug 29 2004, 02:25 PM
Brad Roberts Cool. So you can use a stock flywheel/pp/disc setu... Aug 29 2004, 02:25 PM
sgomes Now THIS is how to spin up a motor on the bench... Aug 29 2004, 02:26 PM
Brad Roberts Ha ha.. we both posted at the exact same time.. TW... Aug 29 2004, 02:26 PM
sgomes Brad, yep it's stock all the way. Ok, I didn... Aug 29 2004, 02:27 PM
sgomes Oh and just cuz... here is the P. Plate: Aug 29 2004, 02:29 PM
sgomes This time for sure.. Aug 29 2004, 02:29 PM
Aaron Cox wow!...
now what do u use as final drive rati... Aug 29 2004, 02:43 PM
sgomes Comparing gas engines to electric motors is always... Aug 29 2004, 02:57 PM
Brando is there any shifting with an electric motor car? ... Aug 29 2004, 03:07 PM
sgomes When you let off the pedal the motor doesn't s... Aug 29 2004, 03:12 PM
Brando how do you engine-brake? Aug 29 2004, 03:23 PM
Rhodes71/914 That's very cool, an electric engine in a 914.... Aug 29 2004, 03:35 PM
sgomes In MY setup I don't engine-brake at all. Yes ... Aug 29 2004, 03:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 10:21 PM |
