> valve adjustment, hope i didnt bent a valve
opera guy
post Aug 29 2004, 03:02 PM
following the article on PP's site, i began to adjust my valves yesterday.
after i found TDC and begin to work on cylinder #1. i took out nut on the intake, and removed the valve adjustment screw to inspect for pitting. the screw looked fine so i put it back in. somehow, the screw wont go back to its prior location. i was only able to screw it in about 6-8 turns. I am positive im not cross-threading it. i think the valve popped out (closed inside the combustion chamber). how do i push the valve INTO the combustion chamber so i can continue threading the valve adjustment screw in and continue to do my adjustment?
please tell me i didnt bent a valve, please!!
nebreitling
post Aug 29 2004, 03:28 PM
Member Emeritus
are you SURE that you were at TDC?
opera guy   valve adjustment   Aug 29 2004, 03:02 PM
Aaron Cox   shouldnt be any load on the rocker when your worki...   Aug 29 2004, 03:04 PM
SpecialK   kinda sounds like your push-rod isn't seated d...   Aug 29 2004, 03:08 PM
nebreitling   are you SURE that you were at TDC?   Aug 29 2004, 03:28 PM
opera guy
- Lo-Fi Version Time is now: 15th March 2026 - 07:16 PM
