| funk |
Jan 19 2015, 02:25 AM
Member ![]() ![]() Group: Members Posts: 100 Joined: 23-June 14 From: sandpoint idaho Member No.: 17,531 Region Association: Pacific Northwest |
I found a sent of 5 lug 6 x 15 inch Porsche fuch wheels. Would they fit on a narrow bodied 914? the key word being 5 lug and I am uncertain if they are what you would call deep sixes??I've seen 914s with 7 inch wheels on narrow bodied.no fender rolling and they fit. then I have seen others where smaller sizes used and they rubbed and were no fit. Is there a way to know all the particulars of 914 narrow bodied fits??I couldn't find any blogs here. Although, I know this has been of interest on our site??
| Dave_Darling |
Jan 19 2015, 12:04 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,298 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
There's no real way to tell ahead of time exactly what fits under a particular 914 without measuring. All of these cars vary a bit, and there is almost always more space inside of one rear fender than the other. (Not always the same side from car to car, either.)
You can measure the space compared to your current wheels and tires, and use the differences in widths and offsets and tire widths and such to approximate the amount of space a different set of wheels and tires would take up, but there are often variations in actual wheel/tire combos from the numbers you calculate. You should be safe running 195-width tires on 6" Fuchs. You have reasonable odds of 205s on the 6es fitting. You have much worse odds of 205s on 7s fitting. Note that you may need to fold over the rear fender lip for clearance in some cases, especially early cars. In later cars, the fender lip was smaller. --DD |
funk 5 lug 6x15 inch fuchs? Jan 19 2015, 02:25 AM
mskala
I found a sent of 5 lug 6 x 15 inch Porsche fuch ... Jan 19 2015, 07:10 AM
Mark Henry They are what I will be using. Look at the back fo... Jan 19 2015, 07:51 AM
napasteve Mine fit just fine with 205/60R15 Goodyear Eagle G... Jan 19 2015, 09:44 AM
wndsnd I am running Deep Six 15's with 205's narr... Jan 19 2015, 11:41 AM
ConeDodger
There's no real way to tell ahead of time exa... Jan 19 2015, 12:14 PM
GeorgeRud My early car did require a bit of fender rollingto... Jan 19 2015, 12:27 PM
horizontally-opposed I am looking at trying to sneak 215/60R15s on 15x7... Jan 19 2015, 01:23 PM
Dave_Darling I know at least one 74 that could not fit 205s on ... Jan 19 2015, 05:12 PM
horizontally-opposed Thanks, Dave! :)
Somewhat apprehensive, but... Jan 26 2015, 11:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th December 2025 - 12:11 AM |
