> Another Sti build., Building my 914GTSTI
914GTSTI
post Nov 8 2012, 05:00 PM
Hello. New here,so here goos.
Back in 2007 started to put the parts and chassie together. I have 3 chassis to work from,2 from Texas and one from Ca. The Texas car seems to be better/less rust but it was hit in the driver front and repaired. Will look into that when I get is up on Rotisserie. Will start building the Rotisserie next.
She will be powered by a JDM Sti using a adapter to the 914 transaxle. Didn't want to go to the Subaru,to much work.
When I get it up on the Rotisserie is this a good time to have blasted clean/paint free?
Here are some photos . Any input is welcome!
Randy
(IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.4.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415655.5.jpg)
914GTSTI
post Jan 29 2015, 11:44 PM
Thanks CptTripps !
Been working and thinking about coil over's for the car. So I started playing with some old stuff for a project I never started.
I will try to reuse the front BOGE tubes/spindles but with KYB's in it ? I can always go Bilsten later. Same with the rear but will need to do some more thinking about that.
Here is my first look at making a coil over. For you at home I have a lath to help with making things fit.Will need to turn the cartridge nut. To big and to close to the spring. Spring is a 10" x 2 1/2". Thinking the front will be 175# and the rear at 200# +- ?
Plan is to weld a perch on the front tube and build a spacer for the rear ? Will try to keep its mounts all stock.
Have also been thinking about the 4 to 5 problem. Most of the GT/lookalikes seam to use spacers to fill out the wheel wells. So think I'm going to use a front adaptor to go 4 to 5/130 ? Still working on what to do to the rear.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422596653.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422596653.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422596653.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422596653.4.jpg)
I know I can just buy it but what fun would that be ?
Randy
914GTSTI   Another Sti build.   Nov 8 2012, 05:00 PM
porbmw   :wttc: Keep us posted, and inspired Paul   Nov 8 2012, 05:05 PM
914GTSTI   Thanks Paul! Also need in put about using the...   Nov 8 2012, 05:19 PM
Andyrew   Thanks Paul! Also need in put about using th...   Nov 8 2012, 10:03 PM
Ductech   Have you driven a 914 with a side shifter? They ar...   Nov 8 2012, 06:02 PM
StratPlayer   :wttc:   Nov 8 2012, 06:06 PM
914GTSTI   Well I drove 140+ miles a day for 3 years with my ...   Nov 8 2012, 06:06 PM
IM101   :wttc: Always happy to see new subaru 914's,...   Nov 8 2012, 07:04 PM
bulitt   What was in it prior? V8?   Nov 8 2012, 07:09 PM
kg6dxn   :wttc: ;   Nov 8 2012, 07:53 PM
914GTSTI   Thanks All! The motor is from a 1994 Sti. She...   Nov 8 2012, 09:39 PM
914GTSTI   Andyrew that was what I was thinking! And the ...   Nov 8 2012, 10:11 PM
914GTSTI   Andyrew that was what I was thinking! And the...   Oct 19 2018, 01:29 PM
Andyrew   The GT look is the most preferred. I have fiberg...   Nov 8 2012, 10:37 PM
ruby914   Have you driven a 914 with a side shifter? They a...   Nov 9 2012, 01:57 AM
914GTSTI   So ,I have been looking at a lot of build photos. ...   Nov 9 2012, 11:39 PM
kg6dxn   So ,I have been looking at a lot of build photos....   Nov 10 2012, 12:15 AM
Dr Evil   So ,I have been looking at a lot of build photos....   Nov 10 2012, 11:31 PM
Porcharu   Never thought about removing the tunnel. The Suba...   Nov 10 2012, 12:06 AM
914GTSTI   Never thought about removing the tunnel. The Sub...   Nov 10 2012, 11:18 PM
914GTSTI   Welded up the ends for the mount. http://www.914wo...   Nov 18 2012, 03:01 PM
914GTSTI   So I got the motor a trans out of storage. I am th...   Nov 20 2012, 05:00 PM
904svo   When I put a Subaru 2007 wrx engine in my kit car ...   Nov 20 2012, 05:19 PM
914GTSTI   Thanks 904! Think I will stay with water. Up f...   Nov 20 2012, 10:45 PM
914GTSTI   Some one was asking,some time back what the FWD tr...   Nov 20 2012, 10:54 PM
914GTSTI   Here is a link to the chassis cleaning/Soda blasti...   Nov 24 2012, 04:46 PM
badmiata   Cant wait to see your progress. Ive been in DBCoop...   Nov 24 2012, 06:43 PM
3d914   Randy, :wttc: Looks like a nice setup. Have yo...   Nov 24 2012, 07:00 PM
914GTSTI   Randy, :wttc: Looks like a nice setup. Have y...   Nov 24 2012, 07:55 PM
914GTSTI   I am moving back over here with rust repair of my ...   Jan 26 2015, 02:11 PM
914GTSTI   From the bottom. http://www.914world.com/bbs2/uplo...   Jan 26 2015, 03:12 PM
914GTSTI   A Little more cleaning. http://www.914world.com/bb...   Jan 26 2015, 06:10 PM
914GTSTI   With me building a water cooled 914 should I pull ...   Jan 26 2015, 06:12 PM
Mike Bellis   Depends on how far you're willing to go... ...   Jan 26 2015, 08:01 PM
914GTSTI   And what about the battery tray ? Not sure their i...   Jan 26 2015, 08:04 PM
Mike Bellis   And what about the battery tray ? Not sure their ...   Jan 26 2015, 08:15 PM
914GTSTI   What about the balance of the car ? With moving th...   Jan 26 2015, 09:30 PM
mgp4591   You're taking weight away from a higher center...   Jan 26 2015, 09:40 PM
76-914   You've already added fans, water and a radiato...   Jan 26 2015, 11:09 PM
mgp4591   You've already added fans, water and a radiat...   Jan 27 2015, 01:11 AM
914GTSTI   I will need to find out what the Subaru starter ne...   Jan 26 2015, 11:57 PM
914GTSTI   So this is my IDEA list. Camber & caster weld...   Jan 27 2015, 10:58 PM
mgp4591   Strip it first of all that's being replaced an...   Jan 28 2015, 12:52 AM
914GTSTI   Thanks for the link to Cpt.Tripps build . I was do...   Jan 28 2015, 01:34 PM
CptTripps   PLEASE ask me questions if you have them! I...   Jan 28 2015, 01:41 PM
914GTSTI   Thanks CptTripps ! Been working and thinking ...   Jan 29 2015, 11:44 PM
914GTSTI   I got a set of Boxster hubs. Now I need to know if...   Feb 4 2015, 12:58 PM
914GTSTI   I, cleaned up a 914-4 brake rotor and bolted (one ...   Feb 5 2015, 05:27 PM
Brian Mifsud   I, cleaned up a 914-4 brake rotor and bolted (one...   Feb 11 2015, 02:27 PM
914forme   Hi Randy, I'd be alot more cautious about ...   Feb 11 2015, 02:47 PM
Brian Mifsud   Hi Randy, I'd be alot more cautious about...   Feb 12 2015, 11:11 AM
914GTSTI   I also found a stud set for the hubs. What kind on...   Feb 5 2015, 05:34 PM
J P Stein   Now here's a pic I havn't posted for a lon...   Feb 5 2015, 08:32 PM
Randal   Now here's a pic I havn't posted for a lo...   Feb 5 2015, 08:35 PM
J P Stein   Aw, come on. the shitbox was always pretty. <_...   Feb 5 2015, 08:47 PM
914GTSTI   So I was looking into do I need the torsion bars i...   Feb 6 2015, 08:38 PM
914GTSTI   In looking at the mount today it will be a pain to...   Feb 7 2015, 10:36 AM
914GTSTI   Got some thing out of the doner. I pulled the hole...   Feb 7 2015, 07:49 PM
914GTSTI   So I trimmed it up,drilled the pilot holes and use...   Feb 7 2015, 09:39 PM
914GTSTI   Back to work. I know this is nothing like the work...   Feb 8 2015, 04:59 PM
914GTSTI   And now its all installed and almost looks stock ?...   Feb 8 2015, 05:06 PM
CptTripps   Nicely done!   Feb 9 2015, 10:25 AM
Mueller   Nicely done! Ditto...and thank you for sav...   Feb 9 2015, 10:31 AM
914GTSTI   Hay CptTripps. Found some wheels you liked on a gr...   Feb 9 2015, 11:09 AM
914GTSTI   A little more work on the Boxster to 108 axle. I...   Feb 9 2015, 02:06 PM
914GTSTI   Well you will need a spacer. I forgot the castle n...   Feb 9 2015, 05:35 PM
914GTSTI   A stiffey ? http://www.914world.com/bbs2/uploads_...   Feb 10 2015, 09:16 PM
914GTSTI   I now have 5x130 and a parking brake ! :Qarl:...   Feb 11 2015, 12:40 PM
914GTSTI   Yes I will use my mill. I now have one stiffie ...   Feb 11 2015, 06:32 PM
914GTSTI   New paint. http://www.914world.com/bbs2/uploads_o...   Feb 12 2015, 05:57 PM
914GTSTI   Looking at the rotor shield and found some crackin...   Feb 14 2015, 12:56 PM
914GTSTI   I was doing some welding and I saw this on the ben...   Feb 14 2015, 02:35 PM
914GTSTI   All installed. 930 CV, cut Boxster Hub, and a 108 ...   Feb 16 2015, 12:44 PM
914GTSTI   Cleaned up the front cross bar and added some pain...   Feb 18 2015, 12:10 PM
914GTSTI   I know the manual said to drive out the bearing an...   Feb 18 2015, 05:12 PM
914GTSTI   Installed the crossbar and found the 11/1971 and t...   Feb 19 2015, 07:38 PM
914GTSTI   And no, i'm not going to use a 300# spring on ...   Feb 19 2015, 07:43 PM
914forme   And no, i'm not going to use a 300# spring on...   Feb 25 2015, 02:55 PM
CptTripps   Great job on the front/rear suspension parts. I po...   Feb 25 2015, 02:22 PM
914forme   Stock 914 T-bars are ~90 lbs/in just to add that l...   Feb 25 2015, 07:12 PM
914GTSTI   Thanks. I was thinking that I would start with 20...   Feb 26 2015, 03:35 PM
914GTSTI   Look what I found . 2005 WRX tran's with LSD ....   Mar 1 2015, 04:15 PM
914GTSTI   Getting ready for my winter project. (914) Been a ...   Oct 27 2015, 01:55 PM
DBCooper   Didn't see this thread before. Very cool.   Oct 27 2015, 02:07 PM
914GTSTI   Now for a motor question. What about the EZ30. Bec...   Oct 27 2015, 02:09 PM
76-914   If your asking me I say EZ30 all the way. Sweet en...   Oct 27 2015, 03:12 PM
flmont   I thought EG33's had the most pwr,..and that ...   Oct 27 2015, 04:46 PM
76-914   I thought EG33's had the most pwr,..and that...   Oct 27 2015, 06:01 PM
Chris H.   I thought EG33's had the most pwr,..and tha...   Oct 27 2015, 07:30 PM
914forme   Go 3.6R :evilgrin: Most HP from a stock sub -6 I...   Oct 27 2015, 07:06 PM
flmont   Ahh,..yea, if that's all,. then most likely a ...   Oct 27 2015, 08:24 PM
914GTSTI   I'm a driver or at least I think I am ? LOL Be...   Oct 28 2015, 08:07 AM
Chris H.   I'm a driver or at least I think I am ? LOL B...   Oct 28 2015, 04:59 PM
76-914   I think I remember reading that there is a perform...   Oct 28 2015, 08:46 AM
914GTSTI   Back on a build. But having trouble with what way ...   Oct 31 2018, 05:27 PM
914GTSTI   Got some parts in. Very nice ! http://www.914...   Nov 10 2018, 01:45 PM
mepstein   MT5   Nov 10 2018, 04:08 PM
914GTSTI   MT5 = Manual Transmission 5 speed, think that is w...   Nov 10 2018, 04:33 PM
914forme   There really should not be a question at this time...   Nov 10 2018, 07:52 PM
Chi-town   That trans is not 05 WRX. The giveaway is it's...   Nov 11 2018, 05:41 PM
- Lo-Fi Version Time is now: 21st September 2026 - 09:45 AM
