> vacum leaks, looking for vacum leaks
T l2 O Y
post Aug 27 2004, 06:24 PM
we are looking for vacum leaks this weekend what sprays do we use?
carb cleaner?
ether starting spray?
we just painted everything in the engine, tin etc. will it remove the paint?
2-OH!
post Aug 30 2004, 02:05 PM
We have tried to jiggle or shake every connector in the engine compartment but none seem to have made any difference...
MPS holds a vacuum, don't know of any other test...
2 of the 4 injectors are new and the others have been cleaned and operate but the spray pattern was not checked...
Temp sensors, don't have a way to check them, the electrical connetions are tight because they don't change the RPM when we wiggle em'...
Cold start valve (AAR) does close after warmup, remove hose, and plug causes no difference...When cold, makes big difference...
I don't know what the TPS is...Can I get more definition ...
Fuel pressure has not been checked...would too much pressure cause high idle...Certainly if it was too low, we would not have high RPM...
2-OH! & TI2OY
- Lo-Fi Version Time is now: 18th March 2026 - 07:23 PM
