Late 5 lug conversion (914 parts drilled) Lug Nut Size, Update: Paid a set to BillH1963 (PMB group buy) |
ndfrigi |
Nov 19 2014, 01:40 AM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
ndfrigi |
Feb 4 2015, 04:27 PM
Update: got the set today.
Can someone give me idea on what lug nut inside length I need for a 45mm stud? I have a set lug nut I bought a while back for my 5 lug conversion but why is it the lug nut I have is short to fit on the studs. I have lug nuts same as the picture below. Allow lug nut with 1.2" inside length. Is it okay if I just insert the stud from the inside of the hub to make the outer stud length shorter to fit my lug nut? (see picture on next post) |
DRPHIL914 |
Feb 4 2015, 07:29 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Update: got the set today. Can someone give me idea on what lug nut inside length I need for a 45mm stud? I have a set lug nut I bought a while back for my 5 lug conversion but why is it the lug nut I have is short to fit on the studs. I have lug nuts same as the picture below. Allow lug nut with 1.2" inside length. Is it okay if I just insert the stud from the inside of the hub to make the outer stud length shorter to fit my lug nut? (see picture on next post) Your welcome glad that worked out. - on the type of lug nut to use, I found the lugs supplied too long for my 14" fuchs . I ordered black lug acorn lug nuts from automotion. I dont know the actual size. I had ordered shorter ones so I have half-inch spacers and am using the shorter closed end nuts now and traded out my long ones for spacers from my mechanic who needed them for another customers 911 so worked out great. I know have 195/65 14s' on with those spacers and still I have plenty of room. But my fender lips have been rolled . That helps a bit. |
Lo-Fi Version | Time is now: 9th June 2024 - 04:24 PM |
