> Another Sti build., Building my 914GTSTI
914GTSTI
post Nov 8 2012, 05:00 PM
Hello. New here,so here goos.
Back in 2007 started to put the parts and chassie together. I have 3 chassis to work from,2 from Texas and one from Ca. The Texas car seems to be better/less rust but it was hit in the driver front and repaired. Will look into that when I get is up on Rotisserie. Will start building the Rotisserie next.
She will be powered by a JDM Sti using a adapter to the 914 transaxle. Didn't want to go to the Subaru,to much work.
When I get it up on the Rotisserie is this a good time to have blasted clean/paint free?
Here are some photos . Any input is welcome!
Randy
(IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.4.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415655.5.jpg)
914GTSTI
post Feb 5 2015, 05:27 PM
I, cleaned up a 914-4 brake rotor and bolted (one hole) to the Boxster hub. It almost self centers. I then tightened up the wheel lug. Used a transfer punch to mark the 5 bolt pattern. Will drill them after getting a bit for a stud mount ? I want to do a mock up so I'm using what I have. Anybody try using allen bolts for wheel studs ? In dirt racing it is a cheep way to go . With some luck the stub's will be here in a day or two ?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1423164673.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1423164673.2.jpg)
The trailing arm is in the bead-blaster for cleaning. Then some welding. Any body on the board sell the metal kits for the chassis and trailing arm's ?
Randy
Brian Mifsud
post Feb 11 2015, 02:27 PM
Mechanical Engineer
QUOTE(914GTSTI @ Feb 5 2015, 03:27 PM) *
Randy
Hi Randy,
I'd be alot more cautious about locating those holes. Using a transfer punch and the hub both introduce significant error. That's a job for a milling machine with a rotary table in my opinion. Otherwise the compounding tolerances could introduce some very unwelcome high speed wobble...
914forme
post Feb 11 2015, 02:47 PM
[/quote]
Hi Randy,
[/quote]
Its not the hub he's drilling, its the rotors. Carry on, it should not be an issues. Just set two points, mark and drill. The lugs do not place the rotor in a perfect alignment. The counter sunk screw does that. Just make sure one of them matches up. And a lug bolt matches up, and go for it.
Brian Mifsud
post Feb 12 2015, 11:11 AM
Mechanical Engineer
[quote name='914forme' date='Feb 11 2015, 12:47 PM' post='2144938']
[/quote]
Hi Randy,
[/quote]
[/quote]
My dad was a Machinist, and I make my living as a Mechanical Engineer. I've always been "belt AND suspenders" so any advice I give is coming from "overkill is just enough"....... My name is Brian and I have TRUST issues..... (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/biggrin.gif)
914GTSTI   Another Sti build.   Nov 8 2012, 05:00 PM
porbmw   :wttc: Keep us posted, and inspired Paul   Nov 8 2012, 05:05 PM
914GTSTI   Thanks Paul! Also need in put about using the...   Nov 8 2012, 05:19 PM
Andyrew   Thanks Paul! Also need in put about using th...   Nov 8 2012, 10:03 PM
Ductech   Have you driven a 914 with a side shifter? They ar...   Nov 8 2012, 06:02 PM
StratPlayer   :wttc:   Nov 8 2012, 06:06 PM
914GTSTI   Well I drove 140+ miles a day for 3 years with my ...   Nov 8 2012, 06:06 PM
IM101   :wttc: Always happy to see new subaru 914's,...   Nov 8 2012, 07:04 PM
bulitt   What was in it prior? V8?   Nov 8 2012, 07:09 PM
kg6dxn   :wttc: ;   Nov 8 2012, 07:53 PM
914GTSTI   Thanks All! The motor is from a 1994 Sti. She...   Nov 8 2012, 09:39 PM
914GTSTI   Andyrew that was what I was thinking! And the ...   Nov 8 2012, 10:11 PM
914GTSTI   Andyrew that was what I was thinking! And the...   Oct 19 2018, 01:29 PM
Andyrew   The GT look is the most preferred. I have fiberg...   Nov 8 2012, 10:37 PM
ruby914   Have you driven a 914 with a side shifter? They a...   Nov 9 2012, 01:57 AM
914GTSTI   So ,I have been looking at a lot of build photos. ...   Nov 9 2012, 11:39 PM
kg6dxn   So ,I have been looking at a lot of build photos....   Nov 10 2012, 12:15 AM
Dr Evil   So ,I have been looking at a lot of build photos....   Nov 10 2012, 11:31 PM
Porcharu   Never thought about removing the tunnel. The Suba...   Nov 10 2012, 12:06 AM
914GTSTI   Never thought about removing the tunnel. The Sub...   Nov 10 2012, 11:18 PM
914GTSTI   Welded up the ends for the mount. http://www.914wo...   Nov 18 2012, 03:01 PM
914GTSTI   So I got the motor a trans out of storage. I am th...   Nov 20 2012, 05:00 PM
904svo   When I put a Subaru 2007 wrx engine in my kit car ...   Nov 20 2012, 05:19 PM
914GTSTI   Thanks 904! Think I will stay with water. Up f...   Nov 20 2012, 10:45 PM
914GTSTI   Some one was asking,some time back what the FWD tr...   Nov 20 2012, 10:54 PM
914GTSTI   Here is a link to the chassis cleaning/Soda blasti...   Nov 24 2012, 04:46 PM
badmiata   Cant wait to see your progress. Ive been in DBCoop...   Nov 24 2012, 06:43 PM
3d914   Randy, :wttc: Looks like a nice setup. Have yo...   Nov 24 2012, 07:00 PM
914GTSTI   Randy, :wttc: Looks like a nice setup. Have y...   Nov 24 2012, 07:55 PM
914GTSTI   I am moving back over here with rust repair of my ...   Jan 26 2015, 02:11 PM
914GTSTI   From the bottom. http://www.914world.com/bbs2/uplo...   Jan 26 2015, 03:12 PM
914GTSTI   A Little more cleaning. http://www.914world.com/bb...   Jan 26 2015, 06:10 PM
914GTSTI   With me building a water cooled 914 should I pull ...   Jan 26 2015, 06:12 PM
Mike Bellis   Depends on how far you're willing to go... ...   Jan 26 2015, 08:01 PM
914GTSTI   And what about the battery tray ? Not sure their i...   Jan 26 2015, 08:04 PM
Mike Bellis   And what about the battery tray ? Not sure their ...   Jan 26 2015, 08:15 PM
914GTSTI   What about the balance of the car ? With moving th...   Jan 26 2015, 09:30 PM
mgp4591   You're taking weight away from a higher center...   Jan 26 2015, 09:40 PM
76-914   You've already added fans, water and a radiato...   Jan 26 2015, 11:09 PM
mgp4591   You've already added fans, water and a radiat...   Jan 27 2015, 01:11 AM
914GTSTI   I will need to find out what the Subaru starter ne...   Jan 26 2015, 11:57 PM
914GTSTI   So this is my IDEA list. Camber & caster weld...   Jan 27 2015, 10:58 PM
mgp4591   Strip it first of all that's being replaced an...   Jan 28 2015, 12:52 AM
914GTSTI   Thanks for the link to Cpt.Tripps build . I was do...   Jan 28 2015, 01:34 PM
CptTripps   PLEASE ask me questions if you have them! I...   Jan 28 2015, 01:41 PM
914GTSTI   Thanks CptTripps ! Been working and thinking ...   Jan 29 2015, 11:44 PM
914GTSTI   I got a set of Boxster hubs. Now I need to know if...   Feb 4 2015, 12:58 PM
914GTSTI   I, cleaned up a 914-4 brake rotor and bolted (one ...   Feb 5 2015, 05:27 PM
Brian Mifsud   I, cleaned up a 914-4 brake rotor and bolted (one...   Feb 11 2015, 02:27 PM
914forme   Hi Randy, I'd be alot more cautious about ...   Feb 11 2015, 02:47 PM
Brian Mifsud   Hi Randy, I'd be alot more cautious about...   Feb 12 2015, 11:11 AM
914GTSTI   I also found a stud set for the hubs. What kind on...   Feb 5 2015, 05:34 PM
J P Stein   Now here's a pic I havn't posted for a lon...   Feb 5 2015, 08:32 PM
Randal   Now here's a pic I havn't posted for a lo...   Feb 5 2015, 08:35 PM
J P Stein   Aw, come on. the shitbox was always pretty. <_...   Feb 5 2015, 08:47 PM
914GTSTI   So I was looking into do I need the torsion bars i...   Feb 6 2015, 08:38 PM
914GTSTI   In looking at the mount today it will be a pain to...   Feb 7 2015, 10:36 AM
914GTSTI   Got some thing out of the doner. I pulled the hole...   Feb 7 2015, 07:49 PM
914GTSTI   So I trimmed it up,drilled the pilot holes and use...   Feb 7 2015, 09:39 PM
914GTSTI   Back to work. I know this is nothing like the work...   Feb 8 2015, 04:59 PM
914GTSTI   And now its all installed and almost looks stock ?...   Feb 8 2015, 05:06 PM
CptTripps   Nicely done!   Feb 9 2015, 10:25 AM
Mueller   Nicely done! Ditto...and thank you for sav...   Feb 9 2015, 10:31 AM
914GTSTI   Hay CptTripps. Found some wheels you liked on a gr...   Feb 9 2015, 11:09 AM
914GTSTI   A little more work on the Boxster to 108 axle. I...   Feb 9 2015, 02:06 PM
914GTSTI   Well you will need a spacer. I forgot the castle n...   Feb 9 2015, 05:35 PM
914GTSTI   A stiffey ? http://www.914world.com/bbs2/uploads_...   Feb 10 2015, 09:16 PM
914GTSTI   I now have 5x130 and a parking brake ! :Qarl:...   Feb 11 2015, 12:40 PM
914GTSTI   Yes I will use my mill. I now have one stiffie ...   Feb 11 2015, 06:32 PM
914GTSTI   New paint. http://www.914world.com/bbs2/uploads_o...   Feb 12 2015, 05:57 PM
914GTSTI   Looking at the rotor shield and found some crackin...   Feb 14 2015, 12:56 PM
914GTSTI   I was doing some welding and I saw this on the ben...   Feb 14 2015, 02:35 PM
914GTSTI   All installed. 930 CV, cut Boxster Hub, and a 108 ...   Feb 16 2015, 12:44 PM
914GTSTI   Cleaned up the front cross bar and added some pain...   Feb 18 2015, 12:10 PM
914GTSTI   I know the manual said to drive out the bearing an...   Feb 18 2015, 05:12 PM
914GTSTI   Installed the crossbar and found the 11/1971 and t...   Feb 19 2015, 07:38 PM
914GTSTI   And no, i'm not going to use a 300# spring on ...   Feb 19 2015, 07:43 PM
914forme   And no, i'm not going to use a 300# spring on...   Feb 25 2015, 02:55 PM
CptTripps   Great job on the front/rear suspension parts. I po...   Feb 25 2015, 02:22 PM
914forme   Stock 914 T-bars are ~90 lbs/in just to add that l...   Feb 25 2015, 07:12 PM
914GTSTI   Thanks. I was thinking that I would start with 20...   Feb 26 2015, 03:35 PM
914GTSTI   Look what I found . 2005 WRX tran's with LSD ....   Mar 1 2015, 04:15 PM
914GTSTI   Getting ready for my winter project. (914) Been a ...   Oct 27 2015, 01:55 PM
DBCooper   Didn't see this thread before. Very cool.   Oct 27 2015, 02:07 PM
914GTSTI   Now for a motor question. What about the EZ30. Bec...   Oct 27 2015, 02:09 PM
76-914   If your asking me I say EZ30 all the way. Sweet en...   Oct 27 2015, 03:12 PM
flmont   I thought EG33's had the most pwr,..and that ...   Oct 27 2015, 04:46 PM
76-914   I thought EG33's had the most pwr,..and that...   Oct 27 2015, 06:01 PM
Chris H.   I thought EG33's had the most pwr,..and tha...   Oct 27 2015, 07:30 PM
914forme   Go 3.6R :evilgrin: Most HP from a stock sub -6 I...   Oct 27 2015, 07:06 PM
flmont   Ahh,..yea, if that's all,. then most likely a ...   Oct 27 2015, 08:24 PM
914GTSTI   I'm a driver or at least I think I am ? LOL Be...   Oct 28 2015, 08:07 AM
Chris H.   I'm a driver or at least I think I am ? LOL B...   Oct 28 2015, 04:59 PM
76-914   I think I remember reading that there is a perform...   Oct 28 2015, 08:46 AM
914GTSTI   Back on a build. But having trouble with what way ...   Oct 31 2018, 05:27 PM
914GTSTI   Got some parts in. Very nice ! http://www.914...   Nov 10 2018, 01:45 PM
mepstein   MT5   Nov 10 2018, 04:08 PM
914GTSTI   MT5 = Manual Transmission 5 speed, think that is w...   Nov 10 2018, 04:33 PM
914forme   There really should not be a question at this time...   Nov 10 2018, 07:52 PM
Chi-town   That trans is not 05 WRX. The giveaway is it's...   Nov 11 2018, 05:41 PM
- Lo-Fi Version Time is now: 21st September 2026 - 09:46 AM
