| BeatNavy |
Feb 17 2015, 05:26 PM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
Getting everything together to install a 2056 into my '72 and swap out the steady, reliable 1.7L I've been running. The 2056 is '73 but came with '74 ECU/MPS combo. The part numbers are 049 on the MPS and 044 on the ECU. Sometimes I'm not sure if I read that ECU/MPS compatibility table on Anders D-Jet site correctly. Is the 049/044 a winning combination?
Also, I've read here that a 2056 really should run with an adjustable MPS. A couple of months ago I converted my 1.7L MPS to adjustable with the Tangerine kit. Any thoughts on whether I could effectively run my MPS (007) just by adjusting it appropriately, or are there other compatibility issues? Or do I need to make that '74 MPS adjustable? Thanks for the help. |
| AndyB |
Feb 19 2015, 10:52 AM
The Governor is watching me ![]() ![]() ![]() Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
Geoff,
Do you have a picture of this spacer? Thanks |
BeatNavy ECU/MPS Compatibility for 2056 Feb 17 2015, 05:26 PM
Jeff Bowlsby Hey Rob, I'm no DJet expert but I think there ... Feb 17 2015, 06:21 PM
BeatNavy Hi Jeff -- thanks for the reply. Now I see where ... Feb 17 2015, 06:35 PM
Bleyseng As long as:
You have a stock grind cam with your 2... Feb 17 2015, 06:42 PM
Jeff Bowlsby
The 049 can be adjusted to run with the 2056 no p... Feb 17 2015, 07:47 PM
914_teener
The 049 can be adjusted to run with the 2056 no ... Feb 17 2015, 09:35 PM
Bleyseng
The 049 can be adjusted to run with the 2056 no ... Feb 18 2015, 09:00 AM
Frank S
As long as:
You have a stock grind cam with your ... Feb 16 2016, 04:54 AM
Bleyseng
As long as:
You have a stock grind cam with your... Feb 16 2016, 08:44 AM
Frank S
[quote name='Frank S' post='2303674' date='Feb 16... Feb 16 2016, 09:39 AM
Bleyseng
[quote name='Frank S' post='2303674' date='Feb 1... Feb 17 2016, 02:45 AM
Frank S
[quote name='Frank S' post='2303719' date='Feb 16... Feb 17 2016, 09:53 AM
Bleyseng
[quote name='Frank S' post='2303719' date='Feb 1... Feb 18 2016, 12:26 AM
worn
It's easier to adjust a MPS using a 044 ECU ... Feb 16 2016, 10:13 AM
BeatNavy Hi Geoff -- good info, thanks. Cam is stock. Sou... Feb 17 2015, 06:47 PM
worn
Hi Geoff -- good info, thanks. Cam is stock. So... Feb 19 2015, 06:25 PM
BeatNavy So Geoff, would you say my best bet is to either:
... Feb 18 2015, 09:20 AM
Bleyseng I have some spacers but you have to take apart the... Feb 18 2015, 05:52 PM
BeatNavy
I have some spacers but you have to take apart th... Feb 18 2015, 06:51 PM
brant I'd love to buy a spacer...
or if these are al... Feb 19 2015, 10:56 AM
Phoenix914 :popcorn:
Rob, thanks for starting this thread.
... Feb 19 2015, 11:14 AM
BeatNavy
:popcorn:
Rob, thanks for starting this thread.... Feb 19 2015, 01:02 PM
Bleyseng Pic of inside a early cover showing the cast in st... Feb 19 2015, 12:06 PM
Scarlet75 Geoff,
Other then being cast this way, some MPS ... Feb 19 2015, 01:44 PM
Racer Chris I have a spacer in my spare parts collection. Thic... Feb 19 2015, 01:53 PM
BeatNavy
I have a spacer in my spare parts collection. Thi... Feb 19 2015, 02:45 PM
Racer Chris
Just to be clear though -- I think they... Feb 19 2015, 04:07 PM
brant
I have a spacer in my spare parts collection. Thi... Feb 19 2015, 02:49 PM
brant I'm struggling to visualize this...
but I want... Feb 19 2015, 02:03 PM
Jeff Bowlsby Chris is the Man for this MPS spacer ring, you alr... Feb 19 2015, 02:52 PM
914_teener There also was a rumor that the springs are differ... Feb 19 2015, 06:30 PM
Bleyseng Springs are differnet between the early and late o... Feb 19 2015, 06:44 PM
914_teener
Springs are differnet between the early and late ... Feb 19 2015, 07:45 PM
Bleyseng
[quote name='Bleyseng' post='2149020' date='Feb 1... Feb 19 2015, 08:14 PM
914_teener
[quote name='Bleyseng' post='2149020' date='Feb ... Feb 19 2015, 09:52 PM
worn
[quote name='Bleyseng' post='2149020' date='Feb ... Feb 22 2015, 06:36 PM
barefoot There are 2 ways to increase fuel flow, everything... Feb 19 2015, 07:05 PM
Bob L.
There are 2 ways to increase fuel flow, everythin... Feb 19 2015, 07:33 PM
barefoot
There are 2 ways to increase fuel flow, everythi... Feb 19 2015, 07:48 PM
Bleyseng Pic of the 2.0L spacer ring Feb 22 2015, 05:35 PM
Racer Chris
Pic of many 2.0L spa... Nov 19 2015, 09:07 AM
914_teener
[quote name='Bleyseng' post='2150304' date='Feb 2... Nov 19 2015, 12:48 PM
Racer Chris
[quote name='Bleyseng' post='2150304' date='Feb ... Nov 19 2015, 03:28 PM
BeatNavy I put the 049 that came with my 2056 into my 1.7L ... Feb 22 2015, 06:54 PM
Bleyseng A 007 will work only if you have a late cover as t... Feb 22 2015, 08:34 PM
BeatNavy Chris - are you selling these now? So a x049 MPS ... Nov 19 2015, 09:36 AM
Racer Chris
I will be wit... Nov 19 2015, 09:40 AM
Olympic 1.7
I will be wi... Nov 19 2015, 07:46 PM
Jeff Bowlsby Anders published values are known to be lean. Nov 19 2015, 10:14 AM
BeatNavy
Re... Nov 19 2015, 10:50 AM
Jeff Bowlsby We're those values adjusted for your local eva... Nov 19 2015, 11:25 AM
BeatNavy Jeff - I did not adjust for sea level, but I'm... Nov 19 2015, 11:31 AM
pbanders I haven't got much to add, Bleyseng and Bowlsb... Nov 19 2015, 01:15 PM
396
I haven't got much to add, Bleyseng and Bowls... Nov 19 2015, 01:31 PM
Bleyseng
I haven't got much to add, Bleyseng and Bowls... Feb 16 2016, 08:48 AM
worn
I haven't got much to add, Bleyseng and Bowls... Feb 16 2016, 10:09 AM
914_teener This has been a great thread for my 2056 D-jet bui... Nov 19 2015, 02:30 PM
BeatNavy
This has been a great thread for my 2056 D-jet bu... Nov 19 2015, 07:15 PM
saigon71 Great info...following this thread closely as I pl... Nov 19 2015, 07:41 PM
BeatNavy I spent a lot of time futzing with my MPS's (I... Feb 16 2016, 10:29 AM
Philip W. this might be slightly off topic but involves the ... Feb 17 2016, 08:06 AM
BeatNavy Those numbers sited on the Anders' site are ta... Feb 17 2016, 09:08 AM
Philip W.
Those numbers sited on the Anders' site are t... Feb 17 2016, 09:46 AM
Philip W. o.k. so as of today I found only one for sale out ... Feb 17 2016, 09:55 AM
worn
o.k. so as of today I found only one for sale out... Feb 17 2016, 10:28 AM
BeatNavy
o.k. so as of today I found only one for sale out... Feb 17 2016, 10:30 AM
sean_v8_914 awesome thread. thank you Feb 17 2016, 11:30 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:42 PM |
