| BeatNavy |
Feb 17 2015, 05:26 PM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
Getting everything together to install a 2056 into my '72 and swap out the steady, reliable 1.7L I've been running. The 2056 is '73 but came with '74 ECU/MPS combo. The part numbers are 049 on the MPS and 044 on the ECU. Sometimes I'm not sure if I read that ECU/MPS compatibility table on Anders D-Jet site correctly. Is the 049/044 a winning combination?
Also, I've read here that a 2056 really should run with an adjustable MPS. A couple of months ago I converted my 1.7L MPS to adjustable with the Tangerine kit. Any thoughts on whether I could effectively run my MPS (007) just by adjusting it appropriately, or are there other compatibility issues? Or do I need to make that '74 MPS adjustable? Thanks for the help. |
| ChrisFoley |
Feb 19 2015, 01:53 PM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
I have a spacer in my spare parts collection. Thickness is .023".
I didn't realize they were only found in 049 units and that they went between the part load plate and the diaphragm to increase the distance to the part load plate. It shouldn't be too hard for me to make a pattern for my laser shop to use. I'll have them made in stainless so no need for plating. |
| BeatNavy |
Feb 19 2015, 02:45 PM
I have a spacer in my spare parts collection. Thickness is .023". I didn't realize they were only found in 049 units and that they went between the part load plate and the diaphragm to increase the distance to the part load plate. It shouldn't be too hard for me to make a pattern for my laser shop to use. I'll have them made in stainless so no need for plating. Chris, that would be great! Just to be clear though -- I think they're only found in 043 units if I'm reading the posts accurately. Is that correct? |
| ChrisFoley |
Feb 19 2015, 04:07 PM
... Just to be clear though -- I think they're only found in 043 units if I'm reading the posts accurately. Is that correct? That's what Geoff and Jeff indicated above. I wrote 049 because I was looking a disassembled one on my desk which already contained the spacer. But the evidence suggests it had been apart once. |
BeatNavy ECU/MPS Compatibility for 2056 Feb 17 2015, 05:26 PM
Jeff Bowlsby Hey Rob, I'm no DJet expert but I think there ... Feb 17 2015, 06:21 PM
BeatNavy Hi Jeff -- thanks for the reply. Now I see where ... Feb 17 2015, 06:35 PM
Bleyseng As long as:
You have a stock grind cam with your 2... Feb 17 2015, 06:42 PM
Jeff Bowlsby
The 049 can be adjusted to run with the 2056 no p... Feb 17 2015, 07:47 PM
914_teener
The 049 can be adjusted to run with the 2056 no ... Feb 17 2015, 09:35 PM
Bleyseng
The 049 can be adjusted to run with the 2056 no ... Feb 18 2015, 09:00 AM
Frank S
As long as:
You have a stock grind cam with your ... Feb 16 2016, 04:54 AM
Bleyseng
As long as:
You have a stock grind cam with your... Feb 16 2016, 08:44 AM
Frank S
[quote name='Frank S' post='2303674' date='Feb 16... Feb 16 2016, 09:39 AM
Bleyseng
[quote name='Frank S' post='2303674' date='Feb 1... Feb 17 2016, 02:45 AM
Frank S
[quote name='Frank S' post='2303719' date='Feb 16... Feb 17 2016, 09:53 AM
Bleyseng
[quote name='Frank S' post='2303719' date='Feb 1... Feb 18 2016, 12:26 AM
worn
It's easier to adjust a MPS using a 044 ECU ... Feb 16 2016, 10:13 AM
BeatNavy Hi Geoff -- good info, thanks. Cam is stock. Sou... Feb 17 2015, 06:47 PM
worn
Hi Geoff -- good info, thanks. Cam is stock. So... Feb 19 2015, 06:25 PM
BeatNavy So Geoff, would you say my best bet is to either:
... Feb 18 2015, 09:20 AM
Bleyseng I have some spacers but you have to take apart the... Feb 18 2015, 05:52 PM
BeatNavy
I have some spacers but you have to take apart th... Feb 18 2015, 06:51 PM
Scarlet75 Geoff,
Do you have a picture of this spacer? Tha... Feb 19 2015, 10:52 AM
brant I'd love to buy a spacer...
or if these are al... Feb 19 2015, 10:56 AM
Phoenix914 :popcorn:
Rob, thanks for starting this thread.
... Feb 19 2015, 11:14 AM
BeatNavy
:popcorn:
Rob, thanks for starting this thread.... Feb 19 2015, 01:02 PM
Bleyseng Pic of inside a early cover showing the cast in st... Feb 19 2015, 12:06 PM
Scarlet75 Geoff,
Other then being cast this way, some MPS ... Feb 19 2015, 01:44 PM
brant
I have a spacer in my spare parts collection. Thi... Feb 19 2015, 02:49 PM
brant I'm struggling to visualize this...
but I want... Feb 19 2015, 02:03 PM
Jeff Bowlsby Chris is the Man for this MPS spacer ring, you alr... Feb 19 2015, 02:52 PM
914_teener There also was a rumor that the springs are differ... Feb 19 2015, 06:30 PM
Bleyseng Springs are differnet between the early and late o... Feb 19 2015, 06:44 PM
914_teener
Springs are differnet between the early and late ... Feb 19 2015, 07:45 PM
Bleyseng
[quote name='Bleyseng' post='2149020' date='Feb 1... Feb 19 2015, 08:14 PM
914_teener
[quote name='Bleyseng' post='2149020' date='Feb ... Feb 19 2015, 09:52 PM
worn
[quote name='Bleyseng' post='2149020' date='Feb ... Feb 22 2015, 06:36 PM
barefoot There are 2 ways to increase fuel flow, everything... Feb 19 2015, 07:05 PM
Bob L.
There are 2 ways to increase fuel flow, everythin... Feb 19 2015, 07:33 PM
barefoot
There are 2 ways to increase fuel flow, everythi... Feb 19 2015, 07:48 PM
Bleyseng Pic of the 2.0L spacer ring Feb 22 2015, 05:35 PM
Racer Chris
Pic of many 2.0L spa... Nov 19 2015, 09:07 AM
914_teener
[quote name='Bleyseng' post='2150304' date='Feb 2... Nov 19 2015, 12:48 PM
Racer Chris
[quote name='Bleyseng' post='2150304' date='Feb ... Nov 19 2015, 03:28 PM
BeatNavy I put the 049 that came with my 2056 into my 1.7L ... Feb 22 2015, 06:54 PM
Bleyseng A 007 will work only if you have a late cover as t... Feb 22 2015, 08:34 PM
BeatNavy Chris - are you selling these now? So a x049 MPS ... Nov 19 2015, 09:36 AM
Racer Chris
I will be wit... Nov 19 2015, 09:40 AM
Olympic 1.7
I will be wi... Nov 19 2015, 07:46 PM
Jeff Bowlsby Anders published values are known to be lean. Nov 19 2015, 10:14 AM
BeatNavy
Re... Nov 19 2015, 10:50 AM
Jeff Bowlsby We're those values adjusted for your local eva... Nov 19 2015, 11:25 AM
BeatNavy Jeff - I did not adjust for sea level, but I'm... Nov 19 2015, 11:31 AM
pbanders I haven't got much to add, Bleyseng and Bowlsb... Nov 19 2015, 01:15 PM
396
I haven't got much to add, Bleyseng and Bowls... Nov 19 2015, 01:31 PM
Bleyseng
I haven't got much to add, Bleyseng and Bowls... Feb 16 2016, 08:48 AM
worn
I haven't got much to add, Bleyseng and Bowls... Feb 16 2016, 10:09 AM
914_teener This has been a great thread for my 2056 D-jet bui... Nov 19 2015, 02:30 PM
BeatNavy
This has been a great thread for my 2056 D-jet bu... Nov 19 2015, 07:15 PM
saigon71 Great info...following this thread closely as I pl... Nov 19 2015, 07:41 PM
BeatNavy I spent a lot of time futzing with my MPS's (I... Feb 16 2016, 10:29 AM
Philip W. this might be slightly off topic but involves the ... Feb 17 2016, 08:06 AM
BeatNavy Those numbers sited on the Anders' site are ta... Feb 17 2016, 09:08 AM
Philip W.
Those numbers sited on the Anders' site are t... Feb 17 2016, 09:46 AM
Philip W. o.k. so as of today I found only one for sale out ... Feb 17 2016, 09:55 AM
worn
o.k. so as of today I found only one for sale out... Feb 17 2016, 10:28 AM
BeatNavy
o.k. so as of today I found only one for sale out... Feb 17 2016, 10:30 AM
sean_v8_914 awesome thread. thank you Feb 17 2016, 11:30 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:01 PM |
