> ECU/MPS Compatibility for 2056, D-Jet Experts?
BeatNavy
post Feb 17 2015, 05:26 PM
Getting everything together to install a 2056 into my '72 and swap out the steady, reliable 1.7L I've been running. The 2056 is '73 but came with '74 ECU/MPS combo. The part numbers are 049 on the MPS and 044 on the ECU. Sometimes I'm not sure if I read that ECU/MPS compatibility table on Anders D-Jet site correctly. Is the 049/044 a winning combination?
Also, I've read here that a 2056 really should run with an adjustable MPS. A couple of months ago I converted my 1.7L MPS to adjustable with the Tangerine kit. Any thoughts on whether I could effectively run my MPS (007) just by adjusting it appropriately, or are there other compatibility issues? Or do I need to make that '74 MPS adjustable?
Thanks for the help.
Bleyseng
post Feb 19 2015, 06:44 PM
Aircooled Baby!
Springs are differnet between the early and late ones as there is a long or short nose MPS
914_teener
post Feb 19 2015, 07:45 PM
QUOTE(Bleyseng @ Feb 19 2015, 04:44 PM) *
Next question that follows if I am allowed:.......still on topic...
Is it known if the spring differnce alters drivability across all three settings for a 2056?
Anyone?
Bleyseng
post Feb 19 2015, 08:14 PM
Aircooled Baby!
QUOTE(914_teener @ Feb 19 2015, 05:45 PM) *
Anyone?
I haven't noticed that the spring rate does anything. Drivability in my experience was related to the diaphragm as the OEM ones were the best so Chris's replacement fixes that problem. Adjusting the MPS with a Raby cam means finding the sweet spot for the cam which usually means a slightly richer idle and faster idle (1050-1100). Other than that once Everything is set up right the 2056 w/raby cam drives like a raped ape.
BeatNavy   ECU/MPS Compatibility for 2056   Feb 17 2015, 05:26 PM
Jeff Bowlsby   Hey Rob, I'm no DJet expert but I think there ...   Feb 17 2015, 06:21 PM
BeatNavy   Hi Jeff -- thanks for the reply. Now I see where ...   Feb 17 2015, 06:35 PM
Bleyseng   As long as: You have a stock grind cam with your 2...   Feb 17 2015, 06:42 PM
Jeff Bowlsby   The 049 can be adjusted to run with the 2056 no p...   Feb 17 2015, 07:47 PM
914_teener   The 049 can be adjusted to run with the 2056 no ...   Feb 17 2015, 09:35 PM
Bleyseng   The 049 can be adjusted to run with the 2056 no ...   Feb 18 2015, 09:00 AM
Frank S   As long as: You have a stock grind cam with your ...   Feb 16 2016, 04:54 AM
Bleyseng   As long as: You have a stock grind cam with your...   Feb 16 2016, 08:44 AM
Frank S   [quote name='Frank S' post='2303674' date='Feb 16...   Feb 16 2016, 09:39 AM
Bleyseng   [quote name='Frank S' post='2303674' date='Feb 1...   Feb 17 2016, 02:45 AM
Frank S   [quote name='Frank S' post='2303719' date='Feb 16...   Feb 17 2016, 09:53 AM
Bleyseng   [quote name='Frank S' post='2303719' date='Feb 1...   Feb 18 2016, 12:26 AM
worn   It's easier to adjust a MPS using a 044 ECU ...   Feb 16 2016, 10:13 AM
BeatNavy   Hi Geoff -- good info, thanks. Cam is stock. Sou...   Feb 17 2015, 06:47 PM
worn   Hi Geoff -- good info, thanks. Cam is stock. So...   Feb 19 2015, 06:25 PM
BeatNavy   So Geoff, would you say my best bet is to either: ...   Feb 18 2015, 09:20 AM
Bleyseng   I have some spacers but you have to take apart the...   Feb 18 2015, 05:52 PM
BeatNavy   I have some spacers but you have to take apart th...   Feb 18 2015, 06:51 PM
Scarlet75   Geoff, Do you have a picture of this spacer? Tha...   Feb 19 2015, 10:52 AM
brant   I'd love to buy a spacer... or if these are al...   Feb 19 2015, 10:56 AM
Phoenix914   :popcorn: Rob, thanks for starting this thread. ...   Feb 19 2015, 11:14 AM
BeatNavy   :popcorn: Rob, thanks for starting this thread....   Feb 19 2015, 01:02 PM
Bleyseng   Pic of inside a early cover showing the cast in st...   Feb 19 2015, 12:06 PM
Scarlet75   Geoff, Other then being cast this way, some MPS ...   Feb 19 2015, 01:44 PM
Racer Chris   I have a spacer in my spare parts collection. Thic...   Feb 19 2015, 01:53 PM
BeatNavy   I have a spacer in my spare parts collection. Thi...   Feb 19 2015, 02:45 PM
Racer Chris   ... Just to be clear though -- I think they...   Feb 19 2015, 04:07 PM
brant   I have a spacer in my spare parts collection. Thi...   Feb 19 2015, 02:49 PM
brant   I'm struggling to visualize this... but I want...   Feb 19 2015, 02:03 PM
Jeff Bowlsby   Chris is the Man for this MPS spacer ring, you alr...   Feb 19 2015, 02:52 PM
914_teener   There also was a rumor that the springs are differ...   Feb 19 2015, 06:30 PM
Bleyseng   Springs are differnet between the early and late o...   Feb 19 2015, 06:44 PM
914_teener   Springs are differnet between the early and late ...   Feb 19 2015, 07:45 PM
Bleyseng   [quote name='Bleyseng' post='2149020' date='Feb 1...   Feb 19 2015, 08:14 PM
914_teener   [quote name='Bleyseng' post='2149020' date='Feb ...   Feb 19 2015, 09:52 PM
worn   [quote name='Bleyseng' post='2149020' date='Feb ...   Feb 22 2015, 06:36 PM
barefoot   There are 2 ways to increase fuel flow, everything...   Feb 19 2015, 07:05 PM
Bob L.   There are 2 ways to increase fuel flow, everythin...   Feb 19 2015, 07:33 PM
barefoot   There are 2 ways to increase fuel flow, everythi...   Feb 19 2015, 07:48 PM
Bleyseng   Pic of the 2.0L spacer ring   Feb 22 2015, 05:35 PM
Racer Chris   Pic of the 2.0L spacer ring Pic of many 2.0L spa...   Nov 19 2015, 09:07 AM
914_teener   [quote name='Bleyseng' post='2150304' date='Feb 2...   Nov 19 2015, 12:48 PM
Racer Chris   [quote name='Bleyseng' post='2150304' date='Feb ...   Nov 19 2015, 03:28 PM
BeatNavy   I put the 049 that came with my 2056 into my 1.7L ...   Feb 22 2015, 06:54 PM
Bleyseng   A 007 will work only if you have a late cover as t...   Feb 22 2015, 08:34 PM
BeatNavy   Chris - are you selling these now? So a x049 MPS ...   Nov 19 2015, 09:36 AM
Racer Chris   Chris - are you selling these now? I will be wit...   Nov 19 2015, 09:40 AM
Olympic 1.7   Chris - are you selling these now? I will be wi...   Nov 19 2015, 07:46 PM
Jeff Bowlsby   Anders published values are known to be lean.   Nov 19 2015, 10:14 AM
BeatNavy   Anders published values are known to be lean. Re...   Nov 19 2015, 10:50 AM
Jeff Bowlsby   We're those values adjusted for your local eva...   Nov 19 2015, 11:25 AM
BeatNavy   Jeff - I did not adjust for sea level, but I'm...   Nov 19 2015, 11:31 AM
pbanders   I haven't got much to add, Bleyseng and Bowlsb...   Nov 19 2015, 01:15 PM
396   I haven't got much to add, Bleyseng and Bowls...   Nov 19 2015, 01:31 PM
Bleyseng   I haven't got much to add, Bleyseng and Bowls...   Feb 16 2016, 08:48 AM
worn   I haven't got much to add, Bleyseng and Bowls...   Feb 16 2016, 10:09 AM
914_teener   This has been a great thread for my 2056 D-jet bui...   Nov 19 2015, 02:30 PM
BeatNavy   This has been a great thread for my 2056 D-jet bu...   Nov 19 2015, 07:15 PM
saigon71   Great info...following this thread closely as I pl...   Nov 19 2015, 07:41 PM
BeatNavy   I spent a lot of time futzing with my MPS's (I...   Feb 16 2016, 10:29 AM
Philip W.   this might be slightly off topic but involves the ...   Feb 17 2016, 08:06 AM
BeatNavy   Those numbers sited on the Anders' site are ta...   Feb 17 2016, 09:08 AM
Philip W.   Those numbers sited on the Anders' site are t...   Feb 17 2016, 09:46 AM
Philip W.   o.k. so as of today I found only one for sale out ...   Feb 17 2016, 09:55 AM
worn   o.k. so as of today I found only one for sale out...   Feb 17 2016, 10:28 AM
BeatNavy   o.k. so as of today I found only one for sale out...   Feb 17 2016, 10:30 AM
sean_v8_914   awesome thread. thank you   Feb 17 2016, 11:30 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:51 AM
