222, Here we go again |
Randal |
Nov 21 2014, 10:50 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Going to put her back together. The D Sport Racer will just have to happen later.
Looking for all good ideas on weight savings. |
returf |
Feb 3 2015, 01:34 AM
Member Group: Members Posts: 67 Joined: 15-August 12 From: New Zealand Member No.: 14,806 Region Association: Australia and New Zealand |
So how'd it run Randal. When do you get to use it again?. I just finished installing a brake upgrade that saved 9lbs per front wheel over the previous setup. 12.2" AP Racing rotors, lightweight Alloy hats and Wilwood forged 4 piston superlites. When you think about trying to say, catch 18lbs of something thrown at you really fast then you start to see the benefits of reducing as much weight as possible (unsprung too) (IMG:style_emoticons/default/smile.gif)
Randal |
Feb 5 2015, 10:11 AM
So how'd it run Randal. When do you get to use it again?. I just finished installing a brake upgrade that saved 9lbs per front wheel over the previous setup. 12.2" AP Racing rotors, lightweight Alloy hats and Wilwood forged 4 piston superlites. When you think about trying to say, catch 18lbs of something thrown at you really fast then you start to see the benefits of reducing as much weight as possible (unsprung too) (IMG:style_emoticons/default/smile.gif) Great point about weight, not sure I want to try and catch a 16#, let alone 18# shotput! Not running yet, but just need to put the transmission back in and the starter, wire and oil her up and should be ready. (IMG:style_emoticons/default/biggrin.gif) |
Randal |
Feb 21 2015, 01:28 PM
So how'd it run Randal. When do you get to use it again?. I just finished installing a brake upgrade that saved 9lbs per front wheel over the previous setup. 12.2" AP Racing rotors, lightweight Alloy hats and Wilwood forged 4 piston superlites. When you think about trying to say, catch 18lbs of something thrown at you really fast then you start to see the benefits of reducing as much weight as possible (unsprung too) (IMG:style_emoticons/default/smile.gif) Great point about weight, not sure I want to try and catch a 16#, let alone 18# shotput! Not running yet, but just need to put the transmission back in and the starter, wire and oil her up and should be ready. (IMG:style_emoticons/default/biggrin.gif) Got the Accusump in and oiled up, transmission and starter on and fired her up. Took a little while, but she finally started. I was using year old race fuel, which was suspect. 222 is now off with a new owner. Packed her up today. Great car, so much fun over the 10 years I owned her. |
Lo-Fi Version | Time is now: 8th June 2024 - 02:46 PM |
