| 914GTSTI |
Nov 8 2012, 05:00 PM
Member ![]() ![]() Group: Members Posts: 275 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
Hello. New here,so here goos.
Back in 2007 started to put the parts and chassie together. I have 3 chassis to work from,2 from Texas and one from Ca. The Texas car seems to be better/less rust but it was hit in the driver front and repaired. Will look into that when I get is up on Rotisserie. Will start building the Rotisserie next. She will be powered by a JDM Sti using a adapter to the 914 transaxle. Didn't want to go to the Subaru,to much work. When I get it up on the Rotisserie is this a good time to have blasted clean/paint free? Here are some photos . Any input is welcome! Randy (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415654.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i916.photobucket.com-8123-1352415655.5.jpg) |
| 914GTSTI |
Feb 19 2015, 07:43 PM
And no, i'm not going to use a 300# spring on the front. And some idiot mounted directional tire on backwards ! What a dip stick.
| 914forme |
Feb 25 2015, 02:55 PM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
And no, i'm not going to use a 300# spring on the front. And some idiot mounted directional tire on backwards ! What a dip stick. I was going to ask if you had calculated out the actual spring rate compared to the torsion bars you are replacing. Stock 911 19mm is ~110 Lb/in These are an upgrade to a 914 btw. 21 mm ~ 175 Lb/in 22 mm ~ 210 Lb/in 23 mm ~ 250 Lb/in 24 mm ~ 300 Lb/in 25 mm ~ 350 Lb/in I never calculated the stock 914-4 bar as I never ran them. I rounded the above numbers to match QA1 springs you can buy. You could go variable, as they make 100-200lbs/in and a 140-250lbs/in, and a 175-350lbs/in. Never thought about using them as I have always gone linear. |
914GTSTI Another Sti build. Nov 8 2012, 05:00 PM
porbmw :wttc:
Keep us posted, and inspired
Paul Nov 8 2012, 05:05 PM
914GTSTI Thanks Paul!
Also need in put about using the... Nov 8 2012, 05:19 PM
Andyrew
Thanks Paul!
Also need in put about using th... Nov 8 2012, 10:03 PM
Ductech Have you driven a 914 with a side shifter? They ar... Nov 8 2012, 06:02 PM
StratPlayer :wttc: Nov 8 2012, 06:06 PM
914GTSTI Well I drove 140+ miles a day for 3 years with my ... Nov 8 2012, 06:06 PM
IM101 :wttc:
Always happy to see new subaru 914's,... Nov 8 2012, 07:04 PM
bulitt What was in it prior? V8? Nov 8 2012, 07:09 PM
kg6dxn :wttc:
; Nov 8 2012, 07:53 PM
914GTSTI Thanks All!
The motor is from a 1994 Sti. She... Nov 8 2012, 09:39 PM
914GTSTI Andyrew that was what I was thinking! And the ... Nov 8 2012, 10:11 PM
914GTSTI
Andyrew that was what I was thinking! And the... Oct 19 2018, 01:29 PM
Andyrew The GT look is the most preferred.
I have fiberg... Nov 8 2012, 10:37 PM
ruby914
Have you driven a 914 with a side shifter? They a... Nov 9 2012, 01:57 AM
914GTSTI So ,I have been looking at a lot of build photos. ... Nov 9 2012, 11:39 PM
kg6dxn
So ,I have been looking at a lot of build photos.... Nov 10 2012, 12:15 AM
Dr Evil
So ,I have been looking at a lot of build photos.... Nov 10 2012, 11:31 PM
Porcharu Never thought about removing the tunnel. The Suba... Nov 10 2012, 12:06 AM
914GTSTI
Never thought about removing the tunnel. The Sub... Nov 10 2012, 11:18 PM
914GTSTI Welded up the ends for the mount.
http://www.914wo... Nov 18 2012, 03:01 PM
914GTSTI So I got the motor a trans out of storage. I am th... Nov 20 2012, 05:00 PM
904svo When I put a Subaru 2007 wrx engine in my kit car ... Nov 20 2012, 05:19 PM
914GTSTI Thanks 904! Think I will stay with water.
Up f... Nov 20 2012, 10:45 PM
914GTSTI Some one was asking,some time back what the FWD tr... Nov 20 2012, 10:54 PM
914GTSTI Here is a link to the chassis cleaning/Soda blasti... Nov 24 2012, 04:46 PM
badmiata Cant wait to see your progress. Ive been in DBCoop... Nov 24 2012, 06:43 PM
3d914 Randy, :wttc:
Looks like a nice setup.
Have yo... Nov 24 2012, 07:00 PM
914GTSTI
Randy, :wttc:
Have y... Nov 24 2012, 07:55 PM
914GTSTI I am moving back over here with rust repair of my ... Jan 26 2015, 02:11 PM
914GTSTI From the bottom.
http://www.914world.com/bbs2/uplo... Jan 26 2015, 03:12 PM
914GTSTI A Little more cleaning.
http://www.914world.com/bb... Jan 26 2015, 06:10 PM
914GTSTI With me building a water cooled 914 should I pull ... Jan 26 2015, 06:12 PM
Mike Bellis Depends on how far you're willing to go... ... Jan 26 2015, 08:01 PM
914GTSTI And what about the battery tray ? Not sure their i... Jan 26 2015, 08:04 PM
Mike Bellis
And what about the battery tray ? Not sure their ... Jan 26 2015, 08:15 PM
914GTSTI What about the balance of the car ? With moving th... Jan 26 2015, 09:30 PM
mgp4591 You're taking weight away from a higher center... Jan 26 2015, 09:40 PM
76-914 You've already added fans, water and a radiato... Jan 26 2015, 11:09 PM
mgp4591
You've already added fans, water and a radiat... Jan 27 2015, 01:11 AM
914GTSTI I will need to find out what the Subaru starter ne... Jan 26 2015, 11:57 PM
914GTSTI So this is my IDEA list.
Camber & caster weld... Jan 27 2015, 10:58 PM
mgp4591 Strip it first of all that's being replaced an... Jan 28 2015, 12:52 AM
914GTSTI Thanks for the link to Cpt.Tripps build . I was do... Jan 28 2015, 01:34 PM
CptTripps PLEASE ask me questions if you have them! I... Jan 28 2015, 01:41 PM
914GTSTI Thanks CptTripps !
Been working and thinking ... Jan 29 2015, 11:44 PM
914GTSTI I got a set of Boxster hubs. Now I need to know if... Feb 4 2015, 12:58 PM
914GTSTI I, cleaned up a 914-4 brake rotor and bolted (one ... Feb 5 2015, 05:27 PM
Brian Mifsud
I, cleaned up a 914-4 brake rotor and bolted (one... Feb 11 2015, 02:27 PM
914forme
Hi Randy,
I'd be alot more cautious about ... Feb 11 2015, 02:47 PM
Brian Mifsud
Hi Randy,
I'd be alot more cautious about... Feb 12 2015, 11:11 AM
914GTSTI I also found a stud set for the hubs. What kind on... Feb 5 2015, 05:34 PM
J P Stein Now here's a pic I havn't posted for a lon... Feb 5 2015, 08:32 PM
Randal
Now here's a pic I havn't posted for a lo... Feb 5 2015, 08:35 PM
J P Stein Aw, come on. the shitbox was always pretty. <_... Feb 5 2015, 08:47 PM
914GTSTI So I was looking into do I need the torsion bars i... Feb 6 2015, 08:38 PM
914GTSTI In looking at the mount today it will be a pain to... Feb 7 2015, 10:36 AM
914GTSTI Got some thing out of the doner. I pulled the hole... Feb 7 2015, 07:49 PM
914GTSTI So I trimmed it up,drilled the pilot holes and use... Feb 7 2015, 09:39 PM
914GTSTI Back to work. I know this is nothing like the work... Feb 8 2015, 04:59 PM
914GTSTI And now its all installed and almost looks stock ?... Feb 8 2015, 05:06 PM
CptTripps Nicely done! Feb 9 2015, 10:25 AM
Mueller
Nicely done!
Ditto...and thank you for sav... Feb 9 2015, 10:31 AM
914GTSTI Hay CptTripps. Found some wheels you liked on a gr... Feb 9 2015, 11:09 AM
914GTSTI A little more work on the Boxster to 108 axle. I... Feb 9 2015, 02:06 PM
914GTSTI Well you will need a spacer. I forgot the castle n... Feb 9 2015, 05:35 PM
914GTSTI A stiffey ?
http://www.914world.com/bbs2/uploads_... Feb 10 2015, 09:16 PM
914GTSTI I now have 5x130 and a parking brake ! :Qarl:... Feb 11 2015, 12:40 PM
914GTSTI Yes I will use my mill.
I now have one stiffie ... Feb 11 2015, 06:32 PM
914GTSTI New paint.
http://www.914world.com/bbs2/uploads_o... Feb 12 2015, 05:57 PM
914GTSTI Looking at the rotor shield and found some crackin... Feb 14 2015, 12:56 PM
914GTSTI I was doing some welding and I saw this on the ben... Feb 14 2015, 02:35 PM
914GTSTI All installed. 930 CV, cut Boxster Hub, and a 108 ... Feb 16 2015, 12:44 PM
914GTSTI Cleaned up the front cross bar and added some pain... Feb 18 2015, 12:10 PM
914GTSTI I know the manual said to drive out the bearing an... Feb 18 2015, 05:12 PM
914GTSTI Installed the crossbar and found the 11/1971 and t... Feb 19 2015, 07:38 PM
CptTripps Great job on the front/rear suspension parts. I po... Feb 25 2015, 02:22 PM
914forme Stock 914 T-bars are ~90 lbs/in just to add that l... Feb 25 2015, 07:12 PM
914GTSTI Thanks.
I was thinking that I would start with 20... Feb 26 2015, 03:35 PM
914GTSTI Look what I found . 2005 WRX tran's with LSD .... Mar 1 2015, 04:15 PM
914GTSTI Getting ready for my winter project. (914) Been a ... Oct 27 2015, 01:55 PM
DBCooper Didn't see this thread before. Very cool. Oct 27 2015, 02:07 PM
914GTSTI Now for a motor question. What about the EZ30. Bec... Oct 27 2015, 02:09 PM
76-914 If your asking me I say EZ30 all the way. Sweet en... Oct 27 2015, 03:12 PM
flmont I thought EG33's had the most pwr,..and that ... Oct 27 2015, 04:46 PM
76-914
I thought EG33's had the most pwr,..and that... Oct 27 2015, 06:01 PM
Chris H.
I thought EG33's had the most pwr,..and tha... Oct 27 2015, 07:30 PM
914forme Go 3.6R :evilgrin: Most HP from a stock sub -6
I... Oct 27 2015, 07:06 PM
flmont Ahh,..yea, if that's all,. then most likely a ... Oct 27 2015, 08:24 PM
914GTSTI I'm a driver or at least I think I am ? LOL Be... Oct 28 2015, 08:07 AM
Chris H.
I'm a driver or at least I think I am ? LOL B... Oct 28 2015, 04:59 PM
76-914 I think I remember reading that there is a perform... Oct 28 2015, 08:46 AM
914GTSTI Back on a build. But having trouble with what way ... Oct 31 2018, 05:27 PM
914GTSTI Got some parts in. Very nice !
http://www.914... Nov 10 2018, 01:45 PM
mepstein MT5 Nov 10 2018, 04:08 PM
914GTSTI MT5 = Manual Transmission 5 speed, think that is w... Nov 10 2018, 04:33 PM
914forme There really should not be a question at this time... Nov 10 2018, 07:52 PM
Chi-town That trans is not 05 WRX. The giveaway is it's... Nov 11 2018, 05:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 21st September 2026 - 09:46 AM |
