Windshield Washer Pump, Which after market pump-while I'm there stuff |
914_teener |
Feb 27 2015, 01:13 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
So going through the Frunk while I have the gas tank out.
Windsheild Washers have never worked. But it looks like a DAPO long ago installation of a factory like rocker switch in the dash is already there. So what is the best aftermarket pump using the stock reservoir? The Bird Board list a VDO for $120......that seems a little heavy. I don't want or need the 924 wiper switch so I figure I just tap the bottom nipple on the stock resivoir and output to the existing nozzles. The fire and the rocker switch is already there. Thoughts and advice on the pump? Anyone used a FLAPS alternative to the VDO? Thanks |
Mike Bellis |
Feb 27 2015, 11:32 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Mueller |
Feb 28 2015, 04:51 PM
I hope that is a misprint on the weight...6 pounds seems a little excessive for a part like that! |
SirAndy |
Feb 28 2015, 05:41 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I hope that is a misprint on the weight...6 pounds seems a little excessive for a part like that! (IMG:style_emoticons/default/confused24.gif) Technical Details Brand: URO Parts Model: 823 955 651 Item Weight: 3.2 ounces |
Lo-Fi Version | Time is now: 8th June 2024 - 10:54 PM |
