So going through the Frunk while I have the gas tank out.
Windsheild Washers have never worked. But it looks like a DAPO long ago installation of a factory like rocker switch in the dash is already there.
So what is the best aftermarket pump using the stock reservoir?
The Bird Board list a VDO for $120......that seems a little heavy.
I don't want or need the 924 wiper switch so I figure I just tap the bottom nipple on the stock resivoir and output to the existing nozzles. The fire and the rocker switch is already there.
Thoughts and advice on the pump? Anyone used a FLAPS alternative to the VDO?
Thanks
