Distributor shaft wear question |
rosenfe |
Mar 1 2015, 06:14 PM
Senior Member Group: Members Posts: 556 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
On my 73 2.0 I have been having issues with dwell fluctuations.i can pull up on shaft that rotor sits on and it moves up and down at least a 1/4 to 1/2 inch.im assuming this is not right and is leading to fluctuations with hard starting .im constantly having to reset pts with dwell meter.
So what can I do ,I have 34 dual carbs and if I replace distributor what do I get.? |
screenguy914 |
Mar 1 2015, 07:19 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Sounds like there's too much vertical play in the distributor shaft. Remove the distributor and inspect. If the cam lobe is okay, add'l thrust washers can be installed to decrease the slop. Otherwise, shop for a replacement in good condition. They should be plentiful, yes?
Sherwood |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:15 AM |
