| PanelBilly |
Mar 1 2015, 06:46 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,950 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
I went to install the shafts today and noticed that the bolts I have are too small (diameter). They are the right size for the transmission side. Aren't they the same?
| Tom |
Mar 1 2015, 07:58 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Billy,
All of the CV bolts are the same. Could you maybe have put the bolt in one of the pin holes? That is one reason why I had wanted to do mine by removing the whole axle to include the stub axle. I had heard of others having line up issues with getting the pins in fully before being able to start the bolts with the stub axle already in the bearing housing. Try starting one or two of the bolts right in the stub axle to make sure the bolts are the right size. Tom, Made it home OK, traffic was pretty light! (IMG:style_emoticons/default/smile.gif) PS: I left my Haynes manual on the rear trunk. (IMG:style_emoticons/default/sad.gif) Just keep it safe for me until we get together again. |
PanelBilly Installing drive shafts Mar 1 2015, 06:46 PM
914Sixer Both sides should be the same M8X48mm Mar 1 2015, 07:25 PM
Steve Did someone do a five lug conversion and use 911 s... Mar 1 2015, 08:01 PM
PanelBilly They are diffinately bigger. I had the 5 lug conve... Mar 1 2015, 09:41 PM
PanelBilly Just found my original paperwork from PMB and it s... Mar 1 2015, 10:05 PM
JRust
Just found my original paperwork from PMB and it ... Mar 1 2015, 10:17 PM
SirAndy you need 911 axles.
911 axles are too short for ... Mar 2 2015, 11:38 AM
Mike Bellis Best prices for new axles is here. You will need t... Mar 1 2015, 10:25 PM
Steve Check the classic threads section to look through ... Mar 1 2015, 10:46 PM
PanelBilly Guess I'm going to be selling my powder coated... Mar 1 2015, 11:32 PM
Larmo63 maybe you need 914-6 stub axles? Mar 2 2015, 12:11 AM
sixnotfour looks like 108's
use 944 stubs/CV and keep y... Mar 2 2015, 02:45 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:03 AM |
