| PanelBilly |
Mar 1 2015, 06:46 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,950 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
I went to install the shafts today and noticed that the bolts I have are too small (diameter). They are the right size for the transmission side. Aren't they the same?
| Steve |
Mar 1 2015, 10:46 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,029 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Check the classic threads section to look through the axle threads.
http://www.914world.com/bbs2/index.php?act=SF&s=&f=5 I am running early 911 stuff with 108mm CV's, stub axles and flanges. Swayaway makes the axles that work with the bigger CV's. All covered in the above classic threads. |
PanelBilly Installing drive shafts Mar 1 2015, 06:46 PM
914Sixer Both sides should be the same M8X48mm Mar 1 2015, 07:25 PM
Tom Billy,
All of the CV bolts are the same. Could... Mar 1 2015, 07:58 PM
Steve Did someone do a five lug conversion and use 911 s... Mar 1 2015, 08:01 PM
PanelBilly They are diffinately bigger. I had the 5 lug conve... Mar 1 2015, 09:41 PM
PanelBilly Just found my original paperwork from PMB and it s... Mar 1 2015, 10:05 PM
JRust
Just found my original paperwork from PMB and it ... Mar 1 2015, 10:17 PM
SirAndy you need 911 axles.
911 axles are too short for ... Mar 2 2015, 11:38 AM
Mike Bellis Best prices for new axles is here. You will need t... Mar 1 2015, 10:25 PM
PanelBilly Guess I'm going to be selling my powder coated... Mar 1 2015, 11:32 PM
Larmo63 maybe you need 914-6 stub axles? Mar 2 2015, 12:11 AM
sixnotfour looks like 108's
use 944 stubs/CV and keep y... Mar 2 2015, 02:45 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:13 PM |
