| PanelBilly |
Mar 4 2015, 12:47 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,950 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
| Downunderman |
Mar 4 2015, 03:05 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
You will find that if you just put hose on it and secure it with a hose clamp it will leak and drive you crazy because when the hose clamp is tightened it will distort the pot metal spout.
Its best to machine up an aluminium extension and glue to the spout with high temp epoxy and connect the hose to that. Cheers, |
| '73-914kid |
Mar 4 2015, 02:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
You will find that if you just put hose on it and secure it with a hose clamp it will leak and drive you crazy because when the hose clamp is tightened it will distort the pot metal spout. Its best to machine up an aluminium extension and glue to the spout with high temp epoxy and connect the hose to that. Cheers, (IMG:style_emoticons/default/beerchug.gif) Ive been fighting an oil leak at the hose for a year now, been through different hose material, different hose clamps, even put some dirko on the hose.. and the damn thing refuses to seal. This sounds easy enough to make. |
PanelBilly Case breather on /6 Mar 4 2015, 12:47 AM
Mike D. It connects via an "expensive" hose to y... Mar 4 2015, 12:53 AM
PanelBilly
It connects via an "expensive" hose to ... Mar 4 2015, 12:59 AM
Cap'n Krusty
You will find that if you just put hose on it and... Mar 5 2015, 10:31 AM
Luke M The engine vents to the oil tank then there's ... Mar 4 2015, 08:15 AM
JmuRiz
The engine vents to the oil tank then there's... Mar 4 2015, 08:59 AM
MJHanna You can run it to a catch can/breather also. Mar 4 2015, 08:19 AM
screenguy914
Ye... Mar 4 2015, 11:33 AM
SirAndy The case vent goes straight to the oil tank:
http... Mar 4 2015, 11:43 AM
patssle You can get colored heater hose cheap on ebay. Thi... Mar 4 2015, 02:30 PM
SirAndy You can get colored heater hose cheap on ebay.
J... Mar 4 2015, 04:45 PM
patssle
... Mar 4 2015, 07:13 PM
SirAndy [quote name='SirAndy' post='2154790' date='Mar 4 2... Mar 4 2015, 10:22 PM
Cap'n Krusty
You can get colored heater hose cheap on ebay. Th... Mar 5 2015, 10:32 AM
PanelBilly Originally I was just planning to clamp the breath... Mar 4 2015, 04:49 PM
jd74914 Yes, I would run it to the intake or a catch can. ... Mar 4 2015, 05:14 PM
johnhora 914-6 GT used this...
http://www.pbase.com/9146gt... Mar 4 2015, 05:36 PM
Jeffs9146 Here is mine! :shades2: Mar 4 2015, 06:44 PM
t collins I wouldn't say it's the best way but has w... Mar 4 2015, 07:48 PM
rgalla9146 Leakage at the breather nipple on the engine shoul... Mar 4 2015, 09:18 PM
Mark Henry Starting to hook this stuff up as well, Howard tha... Mar 5 2015, 10:17 AM
SirAndy Why not make a catch can that drains back into the... Mar 5 2015, 11:17 AM
Mark Henry
Why not make a catch can that drains back into th... Mar 5 2015, 12:23 PM
SirAndy why would a six be any different?
For starters, i... Mar 16 2015, 12:43 AM
'73-914kid I know that the discussion is about where to vent ... Mar 15 2015, 11:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:35 AM |
