Replacement bolts for rear shock to trailing arm, longer to accommodate tie downs? |
stugray |
Feb 28 2015, 03:47 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I bought these tie downs:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1425160022.1.png) But the stock bolts seem to be a little short to stick the tie down between the shock & trailing arm while retaining the thick washer under the stock bolt head. The stock bolt is 18mm X 1.5 X 130mm. The tie down is 5mm. Bolts that large typically come in 10mm increments, so I would need 18mm X 1.5 X 140mm. I have found them but for $25 ea plus shipping. Anyone have a source for the bolts cheaper or a trick to installing these with the stock bolts? Are the bolts that have the attachment points for the rear swaybars just a tiny bit longer? |
Harpo |
Mar 5 2015, 04:02 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Lo-Fi Version | Time is now: 17th June 2024 - 02:32 AM |
