Tuna Can install, Unclear on installation |
LotusJoe |
Mar 10 2015, 12:11 PM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
DRPHIL914 |
Mar 10 2015, 08:20 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I'm in the process of installing the tuna can and am unsure what goes where. Any help is greatly appreciated. I just did this about 6 weeks ago. the strainer goes on the bottom facing upward. the bottom cover goes under that. you will need 3 seals. 1. bottom cover facing up, 2. put seal on this between it and the strainer, and 3. put another seal between the strainer and the tuna can 4 put seal on top of tuna can and attach to car. I don't remember which way the part you were asking about goes, but it will only fit one way. I think the longer part goes down, the shorter up, on top of the strainer. Some choose to use gasket sealer on the seals, I just put oil on them, I have not had a leak since I installed mine. Good Luck. Phil |
LotusJoe |
Mar 11 2015, 12:21 PM
I'm in the process of installing the tuna can and am unsure what goes where. Any help is greatly appreciated. I just did this about 6 weeks ago. the strainer goes on the bottom facing upward. the bottom cover goes under that. you will need 3 seals. 1. bottom cover facing up, 2. put seal on this between it and the strainer, and 3. put another seal between the strainer and the tuna can 4 put seal on top of tuna can and attach to car. I don't remember which way the part you were asking about goes, but it will only fit one way. I think the longer part goes down, the shorter up, on top of the strainer. Some choose to use gasket sealer on the seals, I just put oil on them, I have not had a leak since I installed mine. Good Luck. Phil Thanks Phil, How did you get the long bolt to go thru the strainer? |
ThePaintedMan |
Mar 11 2015, 12:24 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Lo-Fi Version | Time is now: 8th June 2024 - 02:17 AM |
