Considering selling |
gtsdls |
Mar 13 2015, 01:39 PM
Newbie Group: Members Posts: 8 Joined: 28-November 03 From: Vestal, NY Member No.: 1,402 |
Considering selling, trying to value the car. Very original car. I have owned it for 12+ years, the prior owner had it for 6+ always garaged. Originally sold by Holberts in PA, then went south to Delaware. Pictures here- https://www.flickr.com/photos/131142470@N08/
~59000 miles (believed to be original), original 1.8 with fuel injection. Fuchs copies (old American Racing). The car is ultra sold rust wise- anything can be unbolted. SS heater boxes. Center console with operating instruments (clock doesn't keep great time though). Runs well- the engine has never been touched as far as I know. The engine serial number matches the one in the original owners manual. The corner areas in the trunks corners are solid, they were wire brushed/sanded, POR15'd and painted when the engine was out for the new clutch. The rocker panels were removed, pin holes repaired, and repainted, jack cup areas were repaired (welded) with steel replacements and repainted. New shift linkage bushings front to back, clutch plate, clutch cable, pressure plate, rear calipers rebuilt with new pads, SS fuel lines in the engine compartment, all vacuum lines were replaced, rubber fuel lines were replaced, gas filter, plugs, wires, distributor cap, rotor, RedLine trans fluid, rebuilt starter, fan belt, rebuilt pedal cluster. The passenger rear fender was replaced when the car was almost new (I spoke to the original owner several years ago, it happened in the 1st year of ownership) and the paint on that fender and door is showing its age. I touched up the door jams around the vent holes, and the prior owner touched up rock chips. There's a dent near the driver side mirror that can be seen by zooming in. |
rick 918-S |
Mar 13 2015, 02:00 PM
Hey nice rack! -Celette Group: Members Posts: 20,485 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Sounds like a nice car needing only cosmetics. A new paint job will set you back to finish the hard work you have already completed. The 1.8 is not the most desirable engine but if good running that's a plus. Needing paint I would say strong 8-10k. But who am I to say. It's worth what someone is willing to pay.
Lo-Fi Version | Time is now: 6th June 2024 - 09:40 PM |
