> How to check timing on a /6 with engine in car.
tornik550
post Mar 15 2015, 04:48 PM
How do I check timing with a timing light on a /6. I know how to set the static timing however I want to check with a light. I have seen that some cut an acess panel in the firewall. I don't want to do that at this point. There isn't enough room to fit a timing light.
fixer34
post Mar 15 2015, 07:17 PM
AFAIK, and how I've done it, there is an access hole on the top of the case above the flywheel. There are TDC and full advance marks on said flywheel. The hole is large enough to get a finger in there to scrape/sand away rust and put paint on the marks.
The daunting part is that you set the running timing for full advance at 6000 rpm, leaning over the carb stacks. One hand on a timing light, and one to adjust/turn the distributor. Helps to have someone in the cockpit holding the throttle at 6000 also.
larryM
post Mar 15 2015, 08:06 PM
emoze
QUOTE(fixer34 @ Mar 15 2015, 06:17 PM) *
X2
- that's all correct so long as you still have an oem 914/6 flywheel
aftermarket and replacement 911 flywheels have the timing marks in the "wrong" place for the 914/6 viewing slot
if you have a good "advance type ' timing light you set it to ZERO and dial up the advance reading when it turns 6000
you can also do this with a mirror watching the pulley marks (which you have brightly marked) by using a dial-advance type tool
even better - cut a porthole in the firewall like our GT's have, and just do it thru the front - see picture
tornik550   How to check timing on a /6 with engine in car.   Mar 15 2015, 04:48 PM
Mike Bellis   Pull the motor and tranny and start and time it ou...   Mar 15 2015, 04:56 PM
laflaur   Check the timing at the flywheel. There should be ...   Mar 15 2015, 05:09 PM
fixer34   AFAIK, and how I've done it, there is an acces...   Mar 15 2015, 07:17 PM
larryM   AFAIK, and how I've done it, there is an acce...   Mar 15 2015, 08:06 PM
rgalla9146   First step is to pray you have a stock flywheel. ...   Mar 15 2015, 08:21 PM
mskala   First step is to pray you have a stock flywheel. ...   Mar 16 2015, 06:38 AM
rgalla9146   First step is to pray you have a stock flywheel....   Mar 16 2015, 10:41 AM
tornik550   My engine is a 2.7l with JE 9.5:1 compression pist...   Mar 16 2015, 10:26 AM
larryM   CORRECT - just do it even better - first static ...   Mar 16 2015, 03:07 PM
mskala   ... Shouldn't I simply be able to find TDC fo...   Mar 16 2015, 07:34 PM
r_towle   Interesting, I wonder if someone could simply glu...   Mar 16 2015, 05:48 PM
messix   timing at 6k rpm? :screwy: how much more advanc...   Mar 16 2015, 06:02 PM
mskala   timing at 6k rpm? :screwy: how much more advan...   Mar 16 2015, 07:30 PM
fixer34   timing at 6k rpm? :screwy: how much more adva...   Mar 16 2015, 07:46 PM
messix   [quote name='mskala' post='2161069' date='Mar 16 ...   Mar 16 2015, 07:52 PM
messix   and it should be one of the more important things ...   Mar 16 2015, 06:05 PM
patssle   and it should be one of the more important things...   Mar 16 2015, 07:26 PM
messix   nope. please post up one. i have a very hard tim...   Mar 16 2015, 07:45 PM
mskala   nope. please post up one. i have a very hard ti...   Mar 17 2015, 08:39 AM
messix   soo.... it looks like even the worst one is all in...   Mar 17 2015, 07:40 PM
mskala   soo.... it looks like even the worst one is all i...   Mar 18 2015, 08:14 AM
messix   soo.... it looks like even the worst one is all ...   Mar 18 2015, 06:20 PM
Perry Kiehl Clone   If you use a 914-6 flywheel on a 2.4 or 2.7 the ti...   Mar 18 2015, 07:12 AM
SLITS   Jeeeze ... once I set the idle advance/retard, I b...   Mar 18 2015, 08:41 AM
mountainroads   Reviving this old thread because I recently encoun...   Aug 13 2018, 11:31 AM
sixnotfour   Reviving this old thread because I recently encou...   Aug 13 2018, 01:19 PM
Mark Henry   No access problems timing my engine :D http://w...   Aug 13 2018, 01:15 PM
ClayPerrine   No access problems timing my engine :D [img]ht...   Aug 13 2018, 02:45 PM
sixnotfour   OTTO says.... Take dist cap off, stick car in fift...   Aug 13 2018, 01:29 PM
sixnotfour   RE: How to check timing on a /6 with engine in car.   Aug 13 2018, 01:41 PM
Rand   Cutting a hole isn't a problem. Leaving one is...   Aug 13 2018, 03:02 PM
- Lo-Fi Version Time is now: 12th July 2025 - 03:01 PM
