> How to check timing on a /6 with engine in car.
tornik550
post Mar 15 2015, 04:48 PM
How do I check timing with a timing light on a /6. I know how to set the static timing however I want to check with a light. I have seen that some cut an acess panel in the firewall. I don't want to do that at this point. There isn't enough room to fit a timing light.
messix
post Mar 16 2015, 06:05 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
and it should be one of the more important things to remind people to do when doing a 6 conversion is to find absolute tdc and mark the flywheel as such and mark the desired advance mark before the engine is installed.
tornik550   How to check timing on a /6 with engine in car.   Mar 15 2015, 04:48 PM
Mike Bellis   Pull the motor and tranny and start and time it ou...   Mar 15 2015, 04:56 PM
laflaur   Check the timing at the flywheel. There should be ...   Mar 15 2015, 05:09 PM
fixer34   AFAIK, and how I've done it, there is an acces...   Mar 15 2015, 07:17 PM
larryM   AFAIK, and how I've done it, there is an acce...   Mar 15 2015, 08:06 PM
rgalla9146   First step is to pray you have a stock flywheel. ...   Mar 15 2015, 08:21 PM
mskala   First step is to pray you have a stock flywheel. ...   Mar 16 2015, 06:38 AM
rgalla9146   First step is to pray you have a stock flywheel....   Mar 16 2015, 10:41 AM
tornik550   My engine is a 2.7l with JE 9.5:1 compression pist...   Mar 16 2015, 10:26 AM
larryM   CORRECT - just do it even better - first static ...   Mar 16 2015, 03:07 PM
mskala   ... Shouldn't I simply be able to find TDC fo...   Mar 16 2015, 07:34 PM
r_towle   Interesting, I wonder if someone could simply glu...   Mar 16 2015, 05:48 PM
messix   timing at 6k rpm? :screwy: how much more advanc...   Mar 16 2015, 06:02 PM
mskala   timing at 6k rpm? :screwy: how much more advan...   Mar 16 2015, 07:30 PM
fixer34   timing at 6k rpm? :screwy: how much more adva...   Mar 16 2015, 07:46 PM
messix   [quote name='mskala' post='2161069' date='Mar 16 ...   Mar 16 2015, 07:52 PM
messix   and it should be one of the more important things ...   Mar 16 2015, 06:05 PM
patssle   and it should be one of the more important things...   Mar 16 2015, 07:26 PM
messix   nope. please post up one. i have a very hard tim...   Mar 16 2015, 07:45 PM
mskala   nope. please post up one. i have a very hard ti...   Mar 17 2015, 08:39 AM
messix   soo.... it looks like even the worst one is all in...   Mar 17 2015, 07:40 PM
mskala   soo.... it looks like even the worst one is all i...   Mar 18 2015, 08:14 AM
messix   soo.... it looks like even the worst one is all ...   Mar 18 2015, 06:20 PM
Perry Kiehl Clone   If you use a 914-6 flywheel on a 2.4 or 2.7 the ti...   Mar 18 2015, 07:12 AM
SLITS   Jeeeze ... once I set the idle advance/retard, I b...   Mar 18 2015, 08:41 AM
mountainroads   Reviving this old thread because I recently encoun...   Aug 13 2018, 11:31 AM
sixnotfour   Reviving this old thread because I recently encou...   Aug 13 2018, 01:19 PM
Mark Henry   No access problems timing my engine :D http://w...   Aug 13 2018, 01:15 PM
ClayPerrine   No access problems timing my engine :D [img]ht...   Aug 13 2018, 02:45 PM
sixnotfour   OTTO says.... Take dist cap off, stick car in fift...   Aug 13 2018, 01:29 PM
sixnotfour   RE: How to check timing on a /6 with engine in car.   Aug 13 2018, 01:41 PM
Rand   Cutting a hole isn't a problem. Leaving one is...   Aug 13 2018, 03:02 PM
- Lo-Fi Version Time is now: 12th July 2025 - 03:01 PM
