| Larmo63 |
Aug 9 2014, 03:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I know the cars come pre-wired, I now have stock fogs installed on my '73 1.7L, and have a few questions. Should the wires on the front be wired all the way into to foglight bodies? What the factory left is still there, including the rubber grommets so do they wire right through, or should I make connections with the wires coming out of my lights? (does that make sense?) Are all of the correct wires just ready for plug in above the fuse box? My car hasn't been fiddled with, so I have no doubt they will still be there. I bought the bypass wiring kit on eBay so that the fogs will work on the flasher and independently of the headlight switch. Anybody here have comments on that mod? Thanks ahead of time! (IMG:style_emoticons/default/confused24.gif)
| screenguy914 |
Mar 18 2015, 06:26 PM
Member ![]() ![]() Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
I just modified my fog light circuit in my recently-acquired 914 six. After reading numerous docs on the mod., I didn't have that warm and fuzzy feeling nor did I want to let the smoke out of the wire harness, especially after a thread comment that the Haynes version of the 914 wiring diagram was inaccurate. Hmm. What version am I looking at on various websites? Wonderful.
In addition, there are apparently different versions of the light switch even with the same part number (914.613.414.10). This one has 10 spade connectors. There was a pic of this same switch (same part no.), but one of the connectors was labeled differently than mine. Did I want to remove all 10 wire connections to verify the term. ID? No, not even after recording wire colors with my camera. Later switches (e.g. '74) have 11 spade connectors (914.613.414.15). Thankfully, it appears wire color codes remained consistent over the years. Instructions suggest cutting a black/blue wire from a multi-wire connector (58R or 56) and transferring/piggybacking it to another wire/terminal (K or 15). However, different docs suggest different blk/blue wires. I didn't want to risk cutting the wrong one from the headlight harness only to discover it was the wrong one. So I verified the connector IDs by cross referencing the wire colors with the correct connector ID (58b, 58R, 30, 57, K, etc. ), charting voltage levels (0/12V) with the ignition and headlight switches in both ON and OFF positions. After some sleuthing with a DMM and test leads, I ended up making and installing a jumper wire with piggyback connectors to connect term. 56 to K. No vehicle wires were harmed in the process and thus able to return to the previous/next setup if necessary. Here are the results: Previous Ign Sw. ON Headlight Sw. 1st detent - parking lights ON; fog light switch inactive Headlight Sw. 2nd detent - parking lights ON; headlights pop up and ON; fog light switch active After rewiring: Ign Sw. ON or OFF Headlight Sw. 1st detent - parking lights ON; fog light switch active Headlight Sw. 2nd detent - parking lights ON; headlights pop up and ON; fog light switch active This setup provides some options and perhaps more clarity to activate the fog lights. Others may prefer the light circuit dependent on the ignition switch. YMMV. Next mini-project: Install a momentary toggle switch to the circuit to independently flash the fog lights OFF>ON. Hope this helps, Sherwood 3-22-15 Update: A more thorough night time road test revealed the above wiring connection has these repercussions: a. Instrument lights are No Op (NG) b. If: Ign. ON or OFF. fog lts. ON or OFF, with headlights ON: - Pressing Lt switch to the 1st detent (parking lts.) leaves the headlights ON (should be OFF). - High beam indicator is ON (headlights on low beam). Pulling the turn signal stalk momentarily switches the fog lights ON. c. Affect on emergency flashers is unknown (currently no op) Will have to either snip a wire per published wiring mods and confirm that strategy works on this chassis or rewire the fog light circuit independently from the light switch. Probably the latter. Perhaps an opportunity to install a ON-OFF-Mom ON lever switch in place of the factory fog lamp switch. Completion of project at post #35 |
Larmo63 How hard are 914 fogs to wire? Aug 9 2014, 03:04 PM
SirAndy Lets start with the obvious, what year is your car... Aug 9 2014, 03:13 PM
Black22
I know the cars come pre-wired, I now have stock ... Aug 9 2014, 03:14 PM
Larmo63 Delete. Aug 9 2014, 03:18 PM
Black22
Sorry, the car is a '73 and I do have the swi... Aug 9 2014, 06:58 PM
Philip W. My 75 had the wiring already in the trunk, but the... Aug 9 2014, 05:10 PM
Porschef I added fogs along with the bumper backdate on my ... Aug 9 2014, 05:16 PM
toolguy Keep in mind, if you use factory wiring, Fog light... Aug 9 2014, 07:22 PM
Hank914
Keep in mind, if you use factory wiring, Fog ligh... Aug 9 2014, 11:29 PM
smveril I am reinstalling my driving lights on my 73.
The... Aug 10 2014, 06:42 AM
Larmo63 1973 914: What wires am I looking for coming out o... Aug 10 2014, 03:27 PM
worn
1973 914: What wires am I looking for coming out ... Aug 10 2014, 04:51 PM
SirAndy Haynes manual or for color diagrams, go here:
htt... Aug 10 2014, 04:11 PM
Larmo63 Delete. Aug 10 2014, 04:34 PM
SirAndy I get it, I won't ask again.
Jeeze, seriously?... Aug 10 2014, 11:21 PM
Cuda911 Very basic question here:
I've never pulled ... Mar 18 2015, 11:02 PM
Larmo63 Wiring is present behind the grilles. The switches... Mar 19 2015, 08:56 AM
Cuda911
Wiring is present behind the grilles. The switche... Mar 19 2015, 10:59 PM
Dave_Darling
Can I assume the wiring's there?
Is there a b... Mar 19 2015, 09:00 AM
Cuda911 Thanks, guys.
Any of you out there with some fog... Mar 19 2015, 04:39 PM
Larmo63 Bruce Stone should have something. I know somebody... Mar 19 2015, 07:57 PM
Larmo63 http://www.914world.com/bbs2/index.php?showtopic=2... Mar 19 2015, 08:27 PM
Cuda911 Thanks, I sent him a PM. Mar 19 2015, 08:48 PM
Larmo63 http://www.914world.com/bbs2/index.php?showtopic=2... Mar 19 2015, 10:25 PM
Cuda911 Thks again, I sent him a PM. Mar 19 2015, 10:37 PM
Larmo63 http://www.jwesteng.com/shop/index.php?id_...troll... Mar 20 2015, 08:40 AM
Dave_Darling Here's a place that has the Pilot lights:
htt... Mar 20 2015, 10:05 AM
OK, I purchased the lights from PCA... Mar 20 2015, 03:04 PM
screenguy914
Thanks, guys.
OK, I purchased the lights from PC... Mar 21 2015, 03:12 PM
Dave_Darling Heh, Sergio is local to me. He was one of my auto... Mar 20 2015, 07:34 PM
Cuda911 Thanks. Once I have all my stuff assembled, I... Mar 21 2015, 07:35 PM
Larmo63 The hole is there, you will find it. Mar 21 2015, 10:58 PM
Cuda911
Perfecto, ... Mar 22 2015, 10:32 AM
screenguy914 To complete my project posted at #16, I removed th... Mar 27 2015, 01:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:39 PM |
