MPS, Will it work |
MPS, Will it work |
DavidSweden |
Mar 21 2015, 02:35 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am rebuilding my motor 76 2.0 and checked the MPS today. It sucked on it and it does not hold a vacuum, from what I have read it should hold a vacuum. My engine was running before the rebuild and I don't see how it could of got damaged when I removed it.
Do I need to replace it? |
BeatNavy |
Mar 21 2015, 05:32 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Chris provides very good instructions. I did it in about an hour and half one evening. Also, you don't HAVE to install the adjustment piece. You can do only the diaphragm replacement. I also have pictures I can share of the process if needed. It's not hard - go for it!
DavidSweden |
Mar 21 2015, 05:53 PM
Chris provides very good instructions. I did it in about an hour and half one evening. Also, you don't HAVE to install the adjustment piece. You can do only the diaphragm replacement. I also have pictures I can share of the process if needed. It's not hard - go for it! Rob, Yes I want to go for it, I don't understand what do you mean when you say "you don't HAVE to install the adjustment piece"? Can you please explain, thanks |
Lo-Fi Version | Time is now: 7th June 2024 - 07:37 AM |
