MPS, Will it work |
MPS, Will it work |
DavidSweden |
Mar 21 2015, 02:35 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am rebuilding my motor 76 2.0 and checked the MPS today. It sucked on it and it does not hold a vacuum, from what I have read it should hold a vacuum. My engine was running before the rebuild and I don't see how it could of got damaged when I removed it.
Do I need to replace it? |
ChrisFoley |
Mar 21 2015, 06:22 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
If you follow the included directions to replace the diaphragm and seals included in the kit - the MPS will operate as it did before the diaphragm failed.
If you replace the stock stop screw with the one included in my tuning kit, and you install a wideband air/fuel meter in your car, its fairly easy to improve the overall tuning of your engine. |
DavidSweden |
Mar 22 2015, 02:43 AM
If you follow the included directions to replace the diaphragm and seals included in the kit - the MPS will operate as it did before the diaphragm failed. If you replace the stock stop screw with the one included in my tuning kit, and you install a wideband air/fuel meter in your car, its fairly easy to improve the overall tuning of your engine. Chris and everyone Wouldn't a wide band air/fuel meter be overkill for my stock engine (what do they cost, I am a poor European with an expensive hobby). Could someone PM me Tangerines diaphragm installation instructions? I have read the strip down and tuning instruction for the MPS on Rennlist it seems pretty straightforward. However some equipment is required a vacuum pump an LCR meter,. The LCR meter recommended on Rennlist costs about $350the the cost of these products plus the diaphragm kit make it cheaper to buy a reconditioned unit From AutoAtlanta, although this would be not as much fun as repairing the unit myself. Question: If I replace the diaphragm do I need to calibrate using a LCR meter or is there a workaround? Thanks |
Lo-Fi Version | Time is now: 1st June 2024 - 08:43 AM |
