> Fuse confusion. and now it's not starting!, with video!
ripper911
post Mar 25 2015, 04:20 PM
corde pulsum tangite
My car broke down on the way home, between pushing and jumping in and out I knocked out a number of fuses. It's not the first time this has happened, so they probably weren't right to begin with.
So, what amperage goes where?
1974 1.8ish
(IMG:http://www.914world.com/bbs2/uploads_offsite/i921.photobucket.com-11654-1427322057.1.jpg)
ThePaintedMan
post Mar 26 2015, 03:48 PM
If it turns over then you have enough juice in the battery for it to run.
Do you have carbs on this car or FI?
Next, pull a plug wire off, place it close to the tin or other grounded metal part and check to see if you have spark while someone turns it over. It sounds like you do, but verify this first.
Next, if it is carbureted, pull the fuel line off, and put it into a cup. Turn the key to run for 2-3 seconds and see if there is any fuel filling the cup.
Spark, fuel, air are all it needs to run. Check those first then report back.
ripper911   Fuse confusion. and now it's not starting!   Mar 25 2015, 04:20 PM
r_towle   you soooo lazy Pelican has the wiring diagrams......   Mar 25 2015, 04:26 PM
ripper911   <_<   Mar 25 2015, 04:28 PM
r_towle   http://lmgtfy.com/?q=porsche+914+fuse+panel+diagra...   Mar 25 2015, 04:31 PM
ripper911   I guess I need to find some more 8a fuses.   Mar 25 2015, 04:39 PM
ripper911   OK, well now I have another problem. Ever since...   Mar 26 2015, 12:11 PM
ripper911   I could try hitting the starter with a hammer, or ...   Mar 26 2015, 01:37 PM
scotty b   http://www.autoatlanta.com/service/index.php :h...   Mar 26 2015, 02:19 PM
ripper911   I guess they re-did their website. :lol: I don...   Mar 26 2015, 02:30 PM
ripper911   OK, well my alternator belt is a bit loose... But ...   Mar 26 2015, 03:44 PM
ThePaintedMan   If it turns over then you have enough juice in the...   Mar 26 2015, 03:48 PM
ripper911   Carbs.. Fuel, check! I can see it shooting i...   Mar 26 2015, 03:52 PM
Kansas 914   Sounds like it jumped timing.   Mar 26 2015, 04:06 PM
ThePaintedMan   Sounds like it jumped timing. :agree: Perhap...   Mar 26 2015, 04:09 PM
ripper911   :driving: got it home. But still sounding funny ...   Mar 26 2015, 05:31 PM
Porschef   :driving: got it home. I also went through and ...   Mar 26 2015, 06:38 PM
ripper911   How about this? I go to set the timing, as mentio...   Mar 26 2015, 07:34 PM
somd914   Agree it sounds odd, but also note your volt meter...   Mar 27 2015, 03:44 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:25 AM
