> How hard are 914 fogs to wire?
Larmo63
post Aug 9 2014, 03:04 PM
I know the cars come pre-wired, I now have stock fogs installed on my '73 1.7L, and have a few questions. Should the wires on the front be wired all the way into to foglight bodies? What the factory left is still there, including the rubber grommets so do they wire right through, or should I make connections with the wires coming out of my lights? (does that make sense?) Are all of the correct wires just ready for plug in above the fuse box? My car hasn't been fiddled with, so I have no doubt they will still be there. I bought the bypass wiring kit on eBay so that the fogs will work on the flasher and independently of the headlight switch. Anybody here have comments on that mod? Thanks ahead of time! (IMG:style_emoticons/default/confused24.gif)
screenguy914
post Mar 27 2015, 01:28 PM
To complete my project posted at #16, I removed the bridging jumper wire on the light switch due to the issues described.
For safety, remove the battery ground wire before beginning.
I ended up making the fog light circuit independent from the light switch circuit.
Disconnect the black/blue source wire from the fog light switch (E7) and zip-tie the wire to the other fog light wires to isolate it (ID it with tape for future owners). BTW, the black/blue wire is the same wire on term. 56 of the light switch that previous docs suggest snipping and piggybacking onto term. K (on my switch).
Not wanting to cut any factory wires, I left the light switch harness intact. Instead, install a new source circuit from the fuse box directly to the fog light switch. I selected fuse no. 2 (source for voltage to the emergency flasher - constant 12V). Route and attach the new wire to the circuit side of the fuse with a piggyback connector. Since this is merely a control wire for the fog light relay, can be small gauge wire (16-18 ga.).
Route and attach the other wire end with a female spade connector to the now-disconnected fog light male spade connector. Reinstall battery ground cable, then test and confirm before reinstalling fog lamp switch and fuse box (removed for access).
Results:
Factory light switch wire harness not disturbed
Fog lights operational w/Ign. ON or OFF, headlights ON or OFF, UP or DOWN, running lights ON or OFF
Factory wires left intact (except existing fog light source wire disconnected and isolated)
Sherwood
Larmo63   How hard are 914 fogs to wire?   Aug 9 2014, 03:04 PM
SirAndy   Lets start with the obvious, what year is your car...   Aug 9 2014, 03:13 PM
Black22   I know the cars come pre-wired, I now have stock ...   Aug 9 2014, 03:14 PM
Larmo63   Delete.   Aug 9 2014, 03:18 PM
Black22   Sorry, the car is a '73 and I do have the swi...   Aug 9 2014, 06:58 PM
Philip W.   My 75 had the wiring already in the trunk, but the...   Aug 9 2014, 05:10 PM
Porschef   I added fogs along with the bumper backdate on my ...   Aug 9 2014, 05:16 PM
toolguy   Keep in mind, if you use factory wiring, Fog light...   Aug 9 2014, 07:22 PM
Hank914   Keep in mind, if you use factory wiring, Fog ligh...   Aug 9 2014, 11:29 PM
smveril   I am reinstalling my driving lights on my 73. The...   Aug 10 2014, 06:42 AM
Larmo63   1973 914: What wires am I looking for coming out o...   Aug 10 2014, 03:27 PM
worn   1973 914: What wires am I looking for coming out ...   Aug 10 2014, 04:51 PM
SirAndy   Haynes manual or for color diagrams, go here: htt...   Aug 10 2014, 04:11 PM
Larmo63   Delete.   Aug 10 2014, 04:34 PM
SirAndy   I get it, I won't ask again. Jeeze, seriously?...   Aug 10 2014, 11:21 PM
screenguy914   I just modified my fog light circuit in my recentl...   Mar 18 2015, 06:26 PM
Cuda911   Very basic question here: I've never pulled ...   Mar 18 2015, 11:02 PM
Larmo63   Wiring is present behind the grilles. The switches...   Mar 19 2015, 08:56 AM
Cuda911   Wiring is present behind the grilles. The switche...   Mar 19 2015, 10:59 PM
Dave_Darling   Can I assume the wiring's there? Is there a b...   Mar 19 2015, 09:00 AM
Cuda911   Thanks, guys. Any of you out there with some fog...   Mar 19 2015, 04:39 PM
Larmo63   Bruce Stone should have something. I know somebody...   Mar 19 2015, 07:57 PM
Larmo63   http://www.914world.com/bbs2/index.php?showtopic=2...   Mar 19 2015, 08:27 PM
Cuda911   Thanks, I sent him a PM.   Mar 19 2015, 08:48 PM
Larmo63   http://www.914world.com/bbs2/index.php?showtopic=2...   Mar 19 2015, 10:25 PM
Cuda911   Thks again, I sent him a PM.   Mar 19 2015, 10:37 PM
Larmo63   http://www.jwesteng.com/shop/index.php?id_...troll...   Mar 20 2015, 08:40 AM
Dave_Darling   Here's a place that has the Pilot lights: htt...   Mar 20 2015, 10:05 AM
Cuda911   Thanks, guys. OK, I purchased the lights from PCA...   Mar 20 2015, 03:04 PM
screenguy914   Thanks, guys. OK, I purchased the lights from PC...   Mar 21 2015, 03:12 PM
Dave_Darling   Heh, Sergio is local to me. He was one of my auto...   Mar 20 2015, 07:34 PM
Cuda911   Thanks. Once I have all my stuff assembled, I...   Mar 21 2015, 07:35 PM
Larmo63   The hole is there, you will find it.   Mar 21 2015, 10:58 PM
Cuda911   The hole is there, you will find it. Perfecto, ...   Mar 22 2015, 10:32 AM
screenguy914   To complete my project posted at #16, I removed th...   Mar 27 2015, 01:28 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:26 AM
