here we go!, ER f/r rubber bushings!! |
BK911 |
Mar 28 2015, 04:21 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
BK911 |
Mar 29 2015, 02:53 PM
What do you guys think about leaving the old bearings in while blasting and powder coating? I removed the stub axles and bearing retainer plate. Bushings were AFU and metal to metal with the rod and trailing arm!! Glad I decided to do this.
bdstone914 |
Mar 30 2015, 08:12 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
What do you guys think about leaving the old bearings in while blasting and powder coating? I removed the stub axles and bearing retainer plate. Bushings were AFU and metal to metal with the rod and trailing arm!! Glad I decided to do this. Remove the old rubber bushings before powder coating. The heat will turn them into a bubbly mess. I have powder coated the inside bearing area when using poly graphite bushings as some fit too loose. They holes get distorted from cornering. |
Lo-Fi Version | Time is now: 9th June 2024 - 02:04 PM |
