here we go!, ER f/r rubber bushings!! |
BK911 |
Mar 28 2015, 04:21 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
BK911 |
Mar 28 2015, 04:27 PM
SirAndy |
Mar 28 2015, 10:43 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Just on the jack post, not underneath. Thinking of just blasting and por 15 ing. No welding. Whatchu think? POR15 does not work as advertised ... (IMG:style_emoticons/default/dry.gif) I'd replace it with good metal. (IMG:style_emoticons/default/welder.gif) |
malcolm2 |
Mar 31 2015, 09:54 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Just on the jack post, not underneath. Thinking of just blasting and por 15 ing. No welding. Whatchu think? POR15 does not work as advertised ... (IMG:style_emoticons/default/dry.gif) Oh contraire.... What you might have thought you said was, "people don't follow the directions when using POR-15." Which is absolutely true. 3 or 4 steps: 1a. if needed wire brush the hell out of it. 1b. use marine clean, several times at your favorite strength mixture. 2. use metal ready 'til it stops bubbling, rinse thoroughly, dry thoroughly then finally you 3. paint. if 2 coats then hit #2 while #1 is tacky. If #1 drys you have to ruff it up. If the part is going to see sunshine, then you must top coat POR. It does not like UV, gets ashy, but still works. Todays society is MICROWAVE. Everyone wants it NOW. Think CROCK-POT and the world will be a better place. and 90% of painting is the prep. My 2 cents and I don't work for POR. |
Lo-Fi Version | Time is now: 10th June 2024 - 12:18 AM |
