richardL |
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 27-January 03 From: San Diego, CA Member No.: 201 Region Association: None ![]() |
I was trying to fit the new pedal board I have and it won't fit as it keeps binding on the brake pedal. When I played with the pedal I can move it off of the rest towards the master cylinder about 3/4" using one finger. I believe the free play should be closer to 1mm?
Anyhow it seems to me that I should be adjusting the rubber stop forwards to reduce the play - and this would move the rest position of the pedal forwards and reduce the free play and hence also the pedal board to fit in. Is that correct? or am I missing something? OK... How do I do that adjustment? I can't see any way of moving the rubber stop towards the front of the car as it is attached to the bearing tube. Essentially I am trying to stop the spring pushing the pedal up too far, but I can't see how to make that adjustment. I think I have read that the pedal height is adjustable? Hope this is clear, Thanks, Richard |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,291 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Normally the brake pedal adjustment is done with the push rod itself. You unlock the nuts on the back side, and screw the rod in or out to get the required clearance, then lock it up again.
With 17mm clearance instead of 1mm, clearly something is amiss. I cannot imagine what might be wrong. The master cylinder is not bolted to the pedal cluster? The piston in the MC is not coming back to rest position (an internal spring problem)? The brake pushrod was disassembled and not assembled in the original setting? |
Lo-Fi Version | Time is now: 11th July 2025 - 05:12 PM |
