| Cuda911 |
Apr 13 2015, 11:13 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
Some people claim that if you are a a stop light with the car in gear, but clutch pushed all the way in, that it wears out the throwout bearing faster.
I had a lengthy discussion about this with one of our 914World member and a 914 guru of the highest Grand Master level (Mugsy). He convinced me that it is fine to idle at a stop light with the car in gear and clutch pushed in. So, that's what I usually do. Every once in awhile it's tough to get the car in 1st, and I don't want some F150 riding over me when the light turns green and I'm on an easter egg gear hunt. Yesterday I was driving a friend's '71 911, and he started giving me crap for not putting into neutral at lights (Mugsy, you guys got the motor sounding great!). Just thought it would be interesting to solicit the group and see what your thoughts are on this topic. |
| screenguy914 |
Apr 13 2015, 05:24 PM
Member ![]() ![]() Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
My humble comments related to the discussion:
"Even with the tranny in neutral and the clutch engaged, the internal parts are spinning. This is evident if you ever jack up the rear of a car with the engine running. Even if the clutch is disengaged, there is enough drag and kinetic motion to keep parts spinning." The above description means the clutch isn't fully disengaged, even with the clutch pedal floored. There should be no drag or kinetic motion in a vehicle at rest and the transmission disengaged from the drive train. Adjust the free play to properly disengage the clutch mechanism. "The 914 and 411 manuals didn’t really talk about these issues,………" That's because the owner and repair manuals aren't basic automotive reference manuals. Most basic automotive books don't even address this unless there's an intermediate/advanced section on drivetrain diagnosis and repair. However, many posters are correct in their responses. Under the specified conditions: - the TO bearing rotates - the pressure plate fingers are compressed - the force of the pressure plate springs are transferred to the flywheel and crank which increases axial load/wear on the thrust surfaces of the crankshaft main bearings. "No merit whatsoever. Since sometime in the 80s all manual trans cars have a kill switch to prevent one from starting the car without having the clutch released." (referring to crank thrust bearing wear) The last year of the 914 was 1976. Most cars before then did not have a clutch override switch. The above doesn't apply "I coast down until the engine is @ idle speed and put in neutral without using the clutch. At idle speed there is no resistance." When in gear, the input shaft rotates, clutch engaged or disengaged, vehicle at rest or moving. If you wait until the vehicle stops before shifting out of gear, the still engaged drivetrain should cause the engine to stall (all still connected via the clutch). If you move the lever out of gear w/o the clutch, you're separating parts still under a slight load. Some wear - could be insignificant or not. To the original poster, Cuda911. It's not automotive heresy to leave the clutch disengaged at idle, but some wear is caused by this strategy. Difficult shifting into 1st is a common occurrence with early, post 901/915 gearboxes. Sometimes,it's a function of adjusting the proper clutch pedal free play. It's also an expedient short cut owners discover to get into gear when a normal shift from neutral>first is balky. It's a common symptom of worn synchros, especially in 1st and 2nd gears. We can save the whys and solutions for another discussion. |
Cuda911 Opinions on placing car in neutral at stop lights. Apr 13 2015, 11:13 AM
JawjaPorsche The heck with the throw out bearing, I don't w... Apr 13 2015, 11:18 AM
ripper911
The heck with the throw out bearing, I don't ... Apr 13 2015, 11:21 AM
Big Len IDK, heard that too, but I do both. It just depend... Apr 13 2015, 11:20 AM
SirAndy ... I do both. It just depends how far along the l... Apr 13 2015, 11:47 AM
Bruce Hinds If your 1st is hard to get it sounds like you need... Apr 13 2015, 11:28 AM
era vulgaris I'd heard something similar, except that the w... Apr 13 2015, 11:38 AM
Chris914n6
I'd heard something similar, except that the ... Apr 13 2015, 12:19 PM
era vulgaris
[quote name='era vulgaris' post='2173609' date='A... Apr 13 2015, 03:38 PM
Ben and Ralph I have that problem of finding first sometimes as ... Apr 13 2015, 11:38 AM
Mike Bellis Neutral would leave the main shaft spinning. What... Apr 13 2015, 11:51 AM
Olympic 1.7 Similar discussion in the motorcycle community. th... Apr 13 2015, 11:58 AM
eric9144
Similar discussion in the motorcycle community. t... Apr 13 2015, 12:02 PM
DBCooper Yeah, bikes are a little different. Safety is the... Apr 13 2015, 12:14 PM
worn
Some people claim that if you are a a stop light ... Apr 13 2015, 12:29 PM
Mike Bellis Even with the tranny in neutral and the clutch eng... Apr 13 2015, 12:34 PM
damesandhotrods The 914 and 411 manuals didn’t really talk about... Apr 13 2015, 12:40 PM
boxsterfan Step 1: Restore your entire car, bolt-by-bolt, eve... Apr 13 2015, 01:13 PM
Maltese Falcon California DMV driving test = points off /or fail... Apr 13 2015, 01:21 PM
DBCooper
California DMV driving test = points off /or fai... Apr 13 2015, 01:36 PM
KELTY360
and I doubt they'd say to teach something an... Apr 13 2015, 01:58 PM
DBCooper
and I doubt they'd say to teach something a... Apr 13 2015, 02:03 PM
SirAndy California DMV driving test
True story:
When i ... Apr 13 2015, 07:55 PM
r_towle
True story:
When i... Apr 13 2015, 08:04 PM
BK911 So how do you guys put it in neutral?
I coast down... Apr 13 2015, 01:38 PM
Geezer914 I always drop it in neutral when at a stop. When ... Apr 13 2015, 02:23 PM
r_towle This is why all cars should be automatics. Apr 13 2015, 02:52 PM
JawjaPorsche
:b... Apr 13 2015, 02:56 PM
Johny Blackstain Whenever I stop I try to keep it in neutral, regar... Apr 13 2015, 03:06 PM
r_towle I put my automatic in neutral at stop lights...... Apr 13 2015, 03:08 PM
partsman
I put my automatic in neutral at stop lights........ Apr 13 2015, 03:24 PM
dlkawashima I always drop it into neutral at a stop light. Th... Apr 13 2015, 03:46 PM
Elliot Cannon Many years ago, some throw-out bearings weren... Apr 13 2015, 04:56 PM
Mike Bellis
... Apr 13 2015, 08:31 PM
SKL1 Usually put it in N when at lights in all my manua... Apr 13 2015, 08:04 PM
campbellcj I always go to neutral in my (currently 3) manual ... Apr 13 2015, 09:25 PM
euro911 For me, it depends on how long I think I'll be... Apr 13 2015, 09:43 PM
boxsterfan I just leave it in gear, clutch is pressed in and ... Apr 13 2015, 10:12 PM
partsman
I just leave it in gear, clutch is pressed in and... Apr 14 2015, 06:31 AM
mbseto
Different ... Apr 14 2015, 07:36 AM
DBCooper
Different... Apr 14 2015, 08:04 AM
Cuda911 Some very interesting thoughts and comments on thi... Apr 14 2015, 12:59 PM
mbseto
[quote name='mbseto' post='2173998' date='Apr 14 ... Apr 15 2015, 05:43 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:01 PM |
