> Brake Pedal Adjust?
richardL
post Sep 4 2004, 01:23 PM
I was trying to fit the new pedal board I have and it won't fit as it keeps binding on the brake pedal. When I played with the pedal I can move it off of the rest towards the master cylinder about 3/4" using one finger. I believe the free play should be closer to 1mm?
Anyhow it seems to me that I should be adjusting the rubber stop forwards to reduce the play - and this would move the rest position of the pedal forwards and reduce the free play and hence also the pedal board to fit in. Is that correct? or am I missing something?
OK...
How do I do that adjustment? I can't see any way of moving the rubber stop towards the front of the car as it is attached to the bearing tube. Essentially I am trying to stop the spring pushing the pedal up too far, but I can't see how to make that adjustment. I think I have read that the pedal height is adjustable?
Hope this is clear,
Thanks,
Richard
richardL
post Sep 4 2004, 01:58 PM
The brakes worked very well when I last drove it. Is it not equally possible that the MC is fine and the pedal is just continuing to rotate towards the driver even though the cylinder is in the fully 'relaxed' position. You could adjust the pushrod to reduce the free play, but the pedal would still be sitting too high when released - which seems to be my problem because I can't get the pedal board located as the brake pedal is too high and doesn't allow the pedal board to lay flat between the two screw holes.
Thats what started me off.
I have searched and found several remarks saying you can adjust pedal height, but I can't figure out how.
R
richardL   Brake Pedal Adjust?   Sep 4 2004, 01:23 PM
davep   Normally the brake pedal adjustment is done with t...   Sep 4 2004, 01:49 PM
richardL   The brakes worked very well when I last drove it. ...   Sep 4 2004, 01:58 PM
Brad Roberts   The brake pedal is not adjustable (just the free p...   Sep 4 2004, 02:05 PM
richardL   Well that simplifies things. So according to the ...   Sep 4 2004, 02:12 PM
davep   Yes, the finger test is good. Once you start to fe...   Sep 4 2004, 02:25 PM
richardL   I can get the board on, and I can just screw down ...   Sep 4 2004, 02:40 PM
Engman   The pedal boards can be a little tough to get into...   Sep 4 2004, 03:30 PM
Brad Roberts   yeah.. show us a pic.. I know you have a camera......   Sep 4 2004, 03:31 PM
richardL   OK, try these. The board is on and I attach the r...   Sep 4 2004, 03:57 PM
richardL   Now try the other way - attach the left hand mount...   Sep 4 2004, 03:59 PM
richardL   The clutch pedal fits fine, but notice that the bo...   Sep 4 2004, 04:01 PM
Engman   How far off is the other mount hole? M   Sep 4 2004, 04:34 PM
richardL   Whichever side I attach, the board on the other si...   Sep 4 2004, 04:38 PM
Engman   Remove the screw and mount on the lh side. Board l...   Sep 4 2004, 04:54 PM
richardL   Mark, If you look at the first picture I had only...   Sep 4 2004, 05:16 PM
richardL   A few minutes with the saw and I removed that lowe...   Sep 4 2004, 05:38 PM
Jeroen   Richard, It's a little hard to tell by your p...   Sep 4 2004, 06:12 PM
Jeroen   maybe the bolt for the brake stop is missing or br...   Sep 4 2004, 06:13 PM
richardL   The nut is in place and the geometry looks like yo...   Sep 4 2004, 06:24 PM
Jeroen   Weird... Loosen the nuts on the MC and see if you ...   Sep 4 2004, 06:37 PM
Brad Roberts   That is F'd up. :agree: I wonder how the MC c...   Sep 4 2004, 07:07 PM
richardL   All looks OK...   Sep 4 2004, 07:19 PM
richardL   Sorry about the focus...   Sep 4 2004, 07:21 PM
redshift   The rod is properly seated? What is up with that....   Sep 5 2004, 01:20 AM
davep   I don't like the looks of the master, it seems...   Sep 5 2004, 12:04 PM
richardL   So the cluster should be flush with the floor from...   Sep 5 2004, 12:21 PM
Engman   Pull the cluster. lets see what is in there. Shoot...   Sep 5 2004, 01:13 PM
richardL   your wish is my command.... I pulled the cluster ...   Sep 5 2004, 02:45 PM
richardL   and the reason I think is because of two things. 1...   Sep 5 2004, 02:46 PM
richardL   and (2) it looks like the firewall at this point i...   Sep 5 2004, 02:48 PM
richardL   ...inside view....   Sep 5 2004, 02:49 PM
seanery   looks pushed in 1/4 to 1/2" huh?   Sep 5 2004, 02:49 PM
richardL   So... Considering that aesthetics are not importa...   Sep 5 2004, 02:52 PM
richardL     Sep 5 2004, 02:53 PM
sgomes   My 2cents is always the same 2cents: Fix it right...   Sep 5 2004, 02:56 PM
seanery   Shannon, your avatar looks like a clown that was i...   Sep 5 2004, 02:57 PM
sgomes   :chairfall: No, it's really me! It was f...   Sep 5 2004, 03:03 PM
richardL     Sep 5 2004, 03:19 PM
Engman   Yep - its pushed in.... time for :smash: . I am ...   Sep 5 2004, 04:10 PM
richardL   I was able to regain about 1/4" or so (as measured...   Sep 5 2004, 04:29 PM
davep   Well, that about settles what the problem is. Now ...   Sep 5 2004, 05:58 PM
richardL   I had thought of a jack but I need to brace it aga...   Sep 6 2004, 10:05 AM
davep   I would use the crossbar (front seat support) but ...   Sep 7 2004, 11:10 AM
richardL   I don't think the crossbar is a strong as the ...   Sep 7 2004, 12:51 PM
- Lo-Fi Version Time is now: 11th July 2025 - 05:09 PM
