> High Amp Alternator, bolt in application
McMark
post Apr 13 2015, 04:03 PM
914 Freak!
I needed a new alternator for the Turbo 1.7 car and with all of the upgrades I've done I thought I'd look around for a higher amperage unit to install. I know this has been done before, but I wanted something that was a more natural fit. And while I was looking, something with 'modern' technology would be nice.
I found a unit that looked promising and took the leap. It's a built to order, made in the USA unit. It features a built in regulator for a single wire installation, and it's 150 amps (also available in 240 amp! (IMG:style_emoticons/default/ohmy.gif) ).
It finally arrived last week and holding it roughly in place nothing jumped out as a major problem, but there were a few tweaks to the housing. So a little trimming of the two mounting points, a bushing to reduce the pivot shaft diameter to 8mm, and drilling the top mount to 8mm it fits perfectly. Works just like an original unit, has MORE clearance than a stock unit although it weighs quite a bit more. (IMG:style_emoticons/default/wink.gif)
I want to get this installed in my car before I make any promises, but this is looking like a REALLY easy upgrade. NO MORE VOLTAGE REGULATOR!!! (IMG:style_emoticons/default/aktion035.gif)
euro911
post Apr 14 2015, 02:17 AM
Looks good, Mark. Will the OEM alternator tin fit (or will it need to be modified a bit)?
McMark   High Amp Alternator   Apr 13 2015, 04:03 PM
Elliot Cannon   So, what happens when the voltage regulator fails?...   Apr 13 2015, 04:27 PM
Krieger   Good work!   Apr 13 2015, 04:33 PM
Geezer914   Pulley fan or rear cooling duck???   Apr 13 2015, 04:47 PM
Kansas 914   Pulley fan or rear cooling duck??? :popcorn:   Apr 13 2015, 05:27 PM
Elliot Cannon   Pulley fan or rear cooling duck??? :popcorn:   Apr 14 2015, 01:12 AM
worn   Noticed that one too. Very common though. So ...   Apr 22 2015, 11:03 AM
Elliot Cannon   Noticed that one too. Very common though. So...   Apr 22 2015, 11:19 AM
Kansas 914   I think even the HVAC people spell it that way n...   Apr 22 2015, 01:32 PM
euro911   I think even the HVAC people spell it that way now...   Apr 22 2015, 06:36 PM
worn   There is warm air at the North Pole? Also i can h...   Apr 22 2015, 07:03 PM
McMark   The alternator is sold just as it's shown. I...   Apr 13 2015, 05:43 PM
McMark   Looked and theres a fan inside. :thumbsup:   Apr 13 2015, 11:51 PM
Bartlett 914   Looked and theres a fan inside. :thumbsup: Look...   Apr 14 2015, 06:45 AM
euro911   Looks good, Mark. Will the OEM alternator tin fit ...   Apr 14 2015, 02:17 AM
McMark   Just heard back that the alternator is the correc...   Apr 22 2015, 10:53 AM
Bartlett 914   Just heard back that the alternator is the corre...   Apr 22 2015, 01:53 PM
McMark   I'll weigh it tomorrow... :thumbsup:   Apr 22 2015, 09:14 PM
falcor75   Since I'm going the efi route I think I'm ...   May 15 2015, 01:03 PM
McMark   Efi doesn't need high amps. It's more hot ...   May 15 2015, 07:56 PM
worn   Efi doesn't need high amps. It's more hot...   May 15 2015, 08:09 PM
euro911   Any updates, Mark?   May 15 2015, 08:00 PM
boxsterfan   Awesome on this high output alternator!! ...   May 15 2015, 08:12 PM
McMark   Awesome on this high output alternator!! ...   May 15 2015, 09:52 PM
boxsterfan   Awesome on this high output alternator!...   May 16 2015, 12:23 AM
euro911   Yep, an electric heater's been on my list for ...   May 15 2015, 10:58 PM
Dtjaden   Hi Mark, Electric heaters have been discussed bef...   May 16 2015, 10:29 AM
sixnotfour   I have used this one for two years ..works great.....   May 16 2015, 01:08 PM
boxsterfan   I have used this one for two years ..works great....   May 16 2015, 04:46 PM
Dtjaden   Just a caution on the heat output claims many of t...   May 16 2015, 07:40 PM
boxsterfan   Just a caution on the heat output claims many of ...   May 16 2015, 07:44 PM
McMark   Installed this today. Went just as smooth as expec...   May 24 2015, 08:09 PM
boxsterfan   :beer3:   May 24 2015, 09:40 PM
boxsterfan   Did you ever try your electric heat unit? Seat he...   Aug 8 2015, 12:29 PM
MSHax   That's pretty cool! Back in the day I modi...   Aug 8 2015, 12:39 PM
McMark   Not yet. After the move and I get settled in the ...   Aug 8 2015, 12:44 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:05 AM
