richardL |
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 27-January 03 From: San Diego, CA Member No.: 201 Region Association: None ![]() |
I was trying to fit the new pedal board I have and it won't fit as it keeps binding on the brake pedal. When I played with the pedal I can move it off of the rest towards the master cylinder about 3/4" using one finger. I believe the free play should be closer to 1mm?
Anyhow it seems to me that I should be adjusting the rubber stop forwards to reduce the play - and this would move the rest position of the pedal forwards and reduce the free play and hence also the pedal board to fit in. Is that correct? or am I missing something? OK... How do I do that adjustment? I can't see any way of moving the rubber stop towards the front of the car as it is attached to the bearing tube. Essentially I am trying to stop the spring pushing the pedal up too far, but I can't see how to make that adjustment. I think I have read that the pedal height is adjustable? Hope this is clear, Thanks, Richard |
richardL |
Whichever side I attach, the board on the other side is about half to 3/4 inch up in the air over the mount hole - its pivoting on the brake pedal and bearing tube (the big bit at the end that the pedal stop is mounted on). Like I said if I 'bend' the board (and that why I said the wooden one was more accomodating since its easier to bend), I can almost get it to touch but by then the brake pedal is depressed around half an inch. (IMG:style_emoticons/default/headbang.gif)
Richard |
Lo-Fi Version | Time is now: 11th July 2025 - 04:15 PM |
