Rise from the ashes take 2, It looks like I have some work to do |
Phoenix914 |
Feb 13 2015, 11:43 AM
Member Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States |
My car has been sitting for too long. It's time to get it back in driving shape.
While assessing the condition of the engine, I found that the head on the driver's side has some issues to address. Here is the hardware that was holding the intake to the head: I know, right? We have seen this before. Yes, those are threads that came out next to the threaded rod/nut combo on the left. It looks like I have to drop the engine and pull that head. Question: Can anyone recommend a good machine shop in Central Florida to fix the head put the studs back in? |
Phoenix914 |
Apr 16 2015, 09:34 AM
Malcom, for whatever reason the decel valve does look different for D-jet and it looks a lot like the fuel pressure regulator. I had to study them to figure out they were different parts.
You can see them both in this picture. The decel valve is in the foreground, mounted in the incorrect location. The FPR is in it's correct location in the upper right corner. Notice the notched fittings like you described for holding the fuel hoses. The decel valve has smooth pipes. |
audio_file |
Apr 16 2015, 12:08 PM
Member Group: Members Posts: 295 Joined: 6-August 11 From: Everett, Wa Member No.: 13,409 Region Association: Pacific Northwest |
That is most definitely a Fuel Pressure Regulator, not a decel valve...
Phoenix914 |
Apr 16 2015, 12:50 PM
That is most definitely a Fuel Pressure Regulator, not a decel valve... They are crazy similar in appearance. Decel valve Fuel pressure regulator (IMG:style_emoticons/default/smile.gif) |
audio_file |
Apr 16 2015, 12:56 PM
Except for the adjustment bolt on the FPR... which I learned (the hard way) is there just to LOOK AT, not play with, unless you have an inline fuel pressure gague handy (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 28th May 2024 - 08:33 PM |
